Thread: where is my power gains??????
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
  1. #1 where is my power gains??????
    Feb 2009
    racine
    i started moding my car this year and iam confused why it dosnt seem to be getting anymore power.so far i have done cia,pcm,p-log,downpipe,180 tstat,huge zzp wires,autolite 104s.all of the mods i have done are installed correct so thats not it,so am i not going to see anything till i drop pulley sizes or what? i need to know what do next!! although i think my coolant sensor is bad ,does that have anything to do with it ? i have spent about a grand so far, how much more is it going to take to get this thing movin!!
  2. #2 Re: where is my power gains??????
    Donating Users
    South Deerfield, MA
    Most of what you have done are supporting mods for a pulley drop. They don't make noticeable power by themselves, but do when you drop the pulley. If you haven't read it yet, go the safely modding your 3800 thread and read up.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: where is my power gains??????
    Apr 2009
    stockton ca
    you may have gained 15 hp so far but your set up nicely for a 3.4 pulley drop and you will notice the diff
  4. #4 Re: where is my power gains??????
    So basically all you've done is a tune and exhaust work...because wires/plugs/t-stat/intake really don't do anything on these cars.
    Get the 3.4"...you'll see a huge difference then. Don't think it'll be a damn race car though. You won't get there till you put on an IC and drop to a tiny ass pulley or put a cam or rockers in it and re-tune it.
  5. #5 Re: where is my power gains??????
    Willoughby, Ohio
    and make sure you have the rest of your tune up done, fuel filter, fresh engine and tranny oil, all the good stuff
  6. #6 Re: where is my power gains??????
    GT Level Member silvermistchick's Avatar
    Jan 2009
    Atlanta, GA
    that still should give a lil umph, maybe you need to seafoam the car and clean tb??? gf gtp (silvermist) has just fwi,ubend delete,180 t stat,and autolite 605s and she notiecd a lil more pep(got use to it now wants more but.....) but 3.4 pulley needs more exhaust work get headers when you drop pulley and a scanner for monitoring kr
  7. #7 Re: where is my power gains??????
    Jan 1970
    Maquoketa, Iowa
    If the coolant temperature sensor is faulty, that would give you some major problems.
    But unless you drop a pulley size or get a custom tune, your not going to feel any more gains on the butt-dyno.
  8. #8 Re: where is my power gains??????
    caaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaam
  9. #9 Re: where is my power gains??????
    Pennsylvania
    3.4" pulley, re-tune.
  10. #10 Re: where is my power gains??????
    cam it
  11. #11 Re: where is my power gains??????
    Donating Users Ibwrong's Avatar
    Oklahoma City
    cam it
    ^^This.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  12. #12 Re: where is my power gains??????
    Feb 2009
    racine
    thanks for the help!!!!
  13. #13 Re: where is my power gains??????
    GT Level Member scoobyydooooooo's Avatar
    Houston, Texas
    explain cammmmmmm.... how does camming get the power gain? I am interested in this information as well. I just had headers put in, and dropped to a 3.5 pulley. I have 104 plugs, CAI,... After all this, It actually feels like my car is slower than it was when i was stock. I have a tuner working on it now, he has tuned it, but my car still feels worse than stock. I am going to drop to a 3.4 and get a smaller 66" SC belt, hope this helps, any other ideas? sorry for the hijacking of this thread, but it is inline with the topic.
    05 GTP, Inferno Appearance package, SD Headers, 2.9 Pulley, 104 autolites, Wizaired CAI, 180* T-stat, SPO tips, Nav sytem, polymounts, S2IC, XPCAM, much more to come
  14. #14 Re: where is my power gains??????
    GTX Level Member real diehl's Avatar
    Salina, KS
    Quote Originally Posted by scoobyydooooooo View Post
    Before you back-paddled away from this statement, you had me worried about evolution.
    Cams add power. Where they add it varies, and whether or not they sacrifice torque varies also. "Lift" and "duration" allow more air in, and for longer periods of time. They work.
    signature removed for inappropriate content.
    -bio
  15. #15 Re: where is my power gains??????
    If you don't understand how a aftermarket cam makes more power...I suggest reading...its a great tool.
    If not...it allows more airflow...since I don't want to get to technical with you...there are these things called valves and rockers that the cam moves...it allows more air...soo...umm, more power.
  16. #16 Re: where is my power gains??????
    Houston, Texas
    Well, more air does not always equal more power.. If that were the case, simply adding headers would make a huge power increase. a simple cam could actually decrease the power if not combined with a pulley drop or other adjusted mods. Again, this is from what I have "read". Reading and researching is not my issue, getting some inside information from people that have gone thru this is what i am after. But, thanks for not getting to tech on me..
  17. #17 Re: where is my power gains??????
    Tell me how headers are a air ADDING mod?
    They are a flow mod...as in exhaust...they get RID of air.
    As for your car feeling slower...maybe...but it isn't. The headers/pulley/tune you have has merely shifted your powerband to higher RPM's. You want necksnapping torque? Go back to manifolds.
    As for a cam...I had 1.84 Roller Rockers with Ported Manifolds and a 3" DP/U-Bend Delete with a 3.5" pulley and a DHP PCM with other small supporting crap mods...I got rid of all of that for Pacesetter Headers, XP Cam, LS1 TB, 3.2" Pulley, custom tuning...etc. I went from chirping the tires at or around 20 mph to totally annihilating them at 35.
  18. #18 Re: where is my power gains??????
    Houston, Texas
    Ok, now this makes perfect sence.... This is probably the case with my setup. so, is there anything I can do to get the "snap neck" feeling into this car? will the drop to the 3.4 pulley and the new belt make much of a difference? any other good ideas?
  19. #19 Re: where is my power gains??????
    No...not really. Get more mods. Like a cam...or put meth on it...and get a tiny pulley...like a 3.2"
  20. #20 Re: where is my power gains??????
    Topeka, KS
    More Mods will get your TQ back. I know the neck snapping TQ was fun but it makes it a ***** to hook up with. Go to the track and see how much easier it is to hook up and run consistently with headers.
  1. ZZP vs cam setup...Gains?
    By OrangeL67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2012, 11:18 PM
  2. what do you think the gains will be
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-15-2010, 12:43 AM
  3. Best gains for dropping $2000 into a GTP
    By MidnightSpecial in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2010, 11:01 AM
  4. N* gains
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 09:50 AM
  5. Easiest HP gains
    By mikes_comp_g in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 02:17 AM
