Thread: help. bogging, raw fuel, headers...
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 94
  1. #61 Re: help. bogging, raw fuel, headers...
    GT Level Member Mitchstrp's Avatar
    Missouri
    thats about 2 hr drive i may once i fix the misfires. have him check it all out.
    1.8 RR's, Speed daddy headers, 180 stat, Open Cone, GBP tune, 3.5 pulley, and ported blower.
  2. #62 Re: help. bogging, raw fuel, headers...
    Missouri
    *update*
    Car is still running like **** after changing plugs, swapping coils, fixing all vac lines and cleaning MAF sensor.
    So tuesday i plan on pulling the fuel rail, check it for bends or any visual impurities and then clean and check the fuel injectors and also use some sealant and fix my crossover pipe leak.
    Hopefully this will help the misfire on #5 if not, i guess ill change the wires and get the ICM tested.
  3. #63 Re: help. bogging, raw fuel, headers...
    Missouri
    so pulled number 3 and 5 injectors to swap them today and found out that 5's injector was completely ****ed. the piece that holds the bottom oring in place was completely gone, ill have pics up later of the injectors. Went to advanced auto parts and ordered one and itll be here tomorrow morning at 7 am. Hopefully this fixes my problem
  4. #64 Re: help. bogging, raw fuel, headers...
    Delaware, OH
    Sounds like your problem. Without the tip there's no way to direct the fanning spray of fuel so it basically just squirts into The cylinder and puddles.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  5. #65 Re: help. bogging, raw fuel, headers...
    Jul 2008
    sumter,south carolina
    ur buddy prob broke it re-installing it.
    02 GTP with mods 05 GP for DD
  6. #66 Re: help. bogging, raw fuel, headers...
    Missouri
    yeah but my question is... why would he have taken the fuel rail off?
  7. #67 Re: help. bogging, raw fuel, headers...
    Missouri
    see what im talking about?
  8. #68 Re: help. bogging, raw fuel, headers...
    Jul 2008
    oh... i thought u had said teh fuel rail got removed in a previous post. maybe it just got bumped by an elbow or tool and broke. had to break somehow.
  9. #69 Re: help. bogging, raw fuel, headers...
    Missouri
    guess so. hopefully this is the issue
  10. #70 Re: help. bogging, raw fuel, headers...
    I never had the little plastic retainers on the bottom of my injectors...never once had a fueling issue.
  11. #71 Re: help. bogging, raw fuel, headers...
    Missouri
    well i think it may be the problem because all the other injectors have them and 5 didnt and its the injector im having issues with, plus the lower o ring just falls off without that retainer.
  12. #72 Re: help. bogging, raw fuel, headers...
    Are you sure there still isn't an O-Ring in the LIM sitting in the hole for the injector.
  13. #73 Re: help. bogging, raw fuel, headers...
    Missouri
    yeah.. its on in the pic lol it just slides off super easy and i put a new one on it to see if it was just swollen or stretched for some reason and even the new ones slide right off.
  14. #74 Re: help. bogging, raw fuel, headers...
    Missouri
    swapped injectors today and the car is running better already, now ive run into another issue... IF i start the car and let it sick for 5-10 seconds the rpms bounce from 1000 to 2000 then to 500 then cars boggs downs a shuts off. Vac leak or something else?
  15. #75 Re: help. bogging, raw fuel, headers...
    Did you ever replace the MAF...?
    Unplug it...then start it.
  16. #76 Re: help. bogging, raw fuel, headers...
    Missouri
    ill do that tomorrow.
    Went to pick n pull and got me a fuel rail... 11 dollars and 89 cents
  17. #77 Re: help. bogging, raw fuel, headers...
    Bastard Reptile's Avatar
    Kansas City, MO
    Hope I gave you some good tips on checking things, if you need any more help, you've got my cell # now, just give me a shout and I'll do what I can to help ya out. Remember, keep an eye on your gauges.
  18. #78 Re: help. bogging, raw fuel, headers...
    Missouri
    so, alot of you will probably doubt my issue. BUT i changed my fuel rails out and cleaned all the injectors and when i put the new fuel rail in it fit perfectly and the injectors said just right. so i think everythings fixed, as i start the car it turns over perfectly smooth and my boost gauge is reading right around -20.8 to -21.1 so thats about right, i let it sit for about 5 mins to check all vac lines sensors, injectors etc. The car still boggs down! i think i jinxed myself because i called bluegtp91 saying how it was running perfect. so i check everything again and everythings right, my friend said try changing you computer to see if the issue follows. IT DIDNT! i guess my 3800 performance tune was bad and its running fine on the stock pcm. so im sending it back today to have it retuned.
  19. #79 Re: help. bogging, raw fuel, headers...
    20 psi? ...
  20. #80 Re: help. bogging, raw fuel, headers...
    Minnesota
    do you have the U clamps that came with the headers? If you do get band clamps and use a ton of copper RTV on the crossovers that should fix your leak
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  1. car bogging down :(
    By Ricky21 in forum General Tech Discussion
    Last Post: 08-19-2010, 12:55 AM
  2. bogging?
    By backinblackgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2010, 05:03 PM
  3. 97 gtp sputtering and bogging?
    By ebejer13 in forum General Tech Discussion
    Last Post: 05-30-2010, 05:15 PM
  4. '02 GT bogging down-?
    By Wolf02GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2009, 02:53 PM
