Thread: car bogging down :(
Results 1 to 17 of 17
  1. #1 car bogging down :(
    Minnesota
    a little while after putting my headers on i notice my car starting to run a little rough, when i get on it it wont let me accelerate it will start to bog down, also when i first start it up in the morning it will idle very high sometimes up to 2k then will settle back to about 1k, i know i need to put a new rear header gasket on but i dont think that is the only problem maybe a vac leak? any help would be great
  2. #2 Re: car bogging down :(
    vac leak or maf
  3. #3 Re: car bogging down :(
    Minnesota
    would cleaning the maf help out?
  4. #4 Re: car bogging down :(
    Pennsylvania
    Is it unplugged?
  5. #5 Re: car bogging down :(
    Minnesota
    Is what unpluged
  6. #6 Re: car bogging down :(
    he asked if the MAF was unplugged. I'm guessing that it is not and you have a vac leak or the maf is bad or dirty or something else is wrong.
  7. #7 Re: car bogging down :(
    Does it go away when the car is warm?
    Do you have any misfires?
  8. #8 Re: car bogging down :(
    Minnesota
    it idles normal when its warm but stil bogs down on medium to hard throttle, last time i checked for codes it didnt but im gonna scan it again soon
  9. #9 Re: car bogging down :(
  10. #10 Re: car bogging down :(
    Donating Users gtp239's Avatar
    ft myers fl
    mine was doing the same thing felt like a bog but was a missfire check the plugs
    1998 gtp fwi, sd headers, overkill,3.4, poly mounts,p&psc
  11. #11 Re: car bogging down :(
    Minnesota
    I have no cat and just changed my plugs
  12. #12 Re: car bogging down :(
    Minnesota
    So i cleaned the maf and it did nothing then replaced it yesterday and it runs A LOT better now, but it still kinda runs weird i think my uncle said its called surging? is that right? like every second or second and a half it feels like the rpms go up and down maybe 100 rpms its hard to tell unless your feeling for it, could it be a missfire or bad plugs or wires?
  13. #13 Re: car bogging down :(
    maybe a vac leak,
    one more question did you take out the air shield in the intake that in right on the end of the TB, because i took that out on my 97 gtp and it would cause the rpms to jump a little at idle, it would go from 700-800.
  14. #14 Re: car bogging down :(
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by Ricky21 View Post
    Exhaust leak 12 inches or less from the 02 sensor will cause Surging and bogging esp when you first hit the gas after a decal or stop. Bet you toss a p1133 code
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  15. #15 Re: car bogging down :(
    Minnesota
    Quote Originally Posted by 01gpgt01 View Post
    i bet thats it, i had the p1133 code right after the install then put some felpro gaskets in and and put a new maf on and the code went away but it came back and i cleared it and a few days later it came on again, so im gonna get the cross overs welded for sure and proble everything else back, is that a bad idea or does anyone else have all the slipp joints welded?
  16. #16 Re: car bogging down :(
    I do, my three bolt flange is still leaking though.... Gonna fix that on friday.
  17. #17 Re: car bogging down :(
    Minnesota
    ok i was just worried abou tif i had to change anything or take them off but i shouldnt have to worry about gaskets anytime soon so im just gonna get everything welded thanks for the help il let you know how it turns out after that
  1. Bogging out problem???
    By NvMySi in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-08-2010, 12:17 PM
  2. bogging?
    By backinblackgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2010, 05:03 PM
  3. Bogging at 3k under acceleration
    By vertebrate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2009, 10:35 AM
  4. '02 GT bogging down-?
    By Wolf02GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2009, 02:53 PM
  5. Problems with my car bogging down?
    By thenervemann in forum General Tech Discussion
    Last Post: 04-21-2009, 09:05 PM
