but all were correct, tomorrow im going to clean maf and check all vac lines, sensors, ect
okay thanks.
tomorrow im checking:
MAF
Plugs
Wires
o2 sensors
other wire harnesses
correct me if im wrong but my understanding a quick way to check if the maf is having a extremely poor effect on the car is to unplug and the computer should go to a default based on temp and rpm? i did this before but not sure if it applies to gp's
and if he did...? whats the fix? when you say plugs you mean the female right? not the actually piece you plug in
okay, so can i just feel around and see if the plugs are all intact? and if they arent do i replace all the plugs or just that one
