Thread: AjL227's XP, S2 IC, 2.8" CompG build
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 113
  1. #61 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Lower the idleeeeeee
  2. #62 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Portland Oregon
    I saw he had zzp's poly lower motor mount. I have all poly mounts upper and lower and any idle under 950 will rattle the teeth outta your head
  3. #63 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Charles City, IA
    Looks great, I will build one someday.
    SMGPFC Two Nipple General
  4. #64 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Quote Originally Posted by OH4CompG View Post
    Minor details
  5. #65 Re: AjL227's XP, S2 IC, 2.8" CompG build
    GTP Level Member AjL227's Avatar
    IL
    Quote Originally Posted by 99prixgt View Post
    whats your idle set at?
    750 RPM.
    Lower than 750 RPM? And risk oil pressure?
    They don't cause vibrations half as bad as I was expecting from everything I've heard. My set up is poly uppers/lower engine mount, and poly transaxle mount.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  6. #66 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Jersey
    sounds mean as fu ck, i can't wait till my car is done
    16' wrx sti- stock
  7. #67 Re: AjL227's XP, S2 IC, 2.8" CompG build
    I still have over 25psi at idle when warm after I figured out what was up with my car...my idle? Set at 650.
  8. #68 Re: AjL227's XP, S2 IC, 2.8" CompG build
    IL
    The car got washed yesterday. I did a quick photo shoot, and grabbed another idle vid, this time during the day.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  9. #69 Re: AjL227's XP, S2 IC, 2.8" CompG build
    IL
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  10. #70 Re: AjL227's XP, S2 IC, 2.8" CompG build
    IL
    Here is the idle video, I took along with the new pictures after the car wash last week.
    YouTube - CompG GTP X-P Cam
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  11. #71 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Jersey
    i love it
    wot video please
    16' wrx sti- stock
  12. #72 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Banned
    Sioux Falls, SD
    Im doing the xp build just like yours with the double chain, what did the machine shop have to do to match the crank gear for the timing chain?
  13. #73 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    wehat exhaust do u ahve man? and i love it
  14. #74 Re: AjL227's XP, S2 IC, 2.8" CompG build
    change the bevel.
    If you bring both gears they should be able to figure it out.
  15. #75 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Banned
    Sioux Falls, SD
    Quote Originally Posted by That Canadian Guy View Post
    change the bevel.
    Thanks matt, then i dont need the double gasket or machined pump cover
  16. #76 Re: AjL227's XP, S2 IC, 2.8" CompG build
    You shouldn't.
    But i think the machined pump cover might still be required.
  17. #77 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Banned
    Sioux Falls, SD
    yea i planned on getting that done
  18. #78 Re: AjL227's XP, S2 IC, 2.8" CompG build
    check clearance for sure.
  19. #79 Re: AjL227's XP, S2 IC, 2.8" CompG build
    ATX
    Hows traction? Id really like to see some incar pulls.
  20. #80 Re: AjL227's XP, S2 IC, 2.8" CompG build
    IL
    Rollmaster and JP double roller timing sets were manufactured for the Australian 3800 crank's. As long as the crank gear key way chamfer, and cam gear are machined within proper offset tolerances of each other, you only need to double gasket to be golden. This is assuming, both gears are fully seated as they should be. The machined oil pump cover is only needed, if you improperly installed your timing set.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  1. Are the compg gtp's faster than the non compg gtp's?
    By GMCARS4LIFE in forum Off Topic Discussion
    Last Post: 03-07-2011, 09:19 PM
  2. Turbo Build "UPDATED 12/22/2010"
    By bbptech in forum Turbo
    Last Post: 12-22-2010, 12:06 PM
  3. 04 CompG from MN here, Hello!
    By chili in forum Introductions/Noob Questions
    Last Post: 06-06-2009, 05:15 AM
  4. My CompG
    By RKELC in forum Visual/Body Modifications
    Last Post: 04-29-2008, 06:57 PM
