Lower the idleeeeeee
750 RPM.
Lower than 750 RPM? And risk oil pressure?
They don't cause vibrations half as bad as I was expecting from everything I've heard. My set up is poly uppers/lower engine mount, and poly transaxle mount.
sounds mean as fu ck, i can't wait till my car is done
I still have over 25psi at idle when warm after I figured out what was up with my car...my idle? Set at 650.
Here is the idle video, I took along with the new pictures after the car wash last week.
YouTube - CompG GTP X-P Cam
i love it
wot video please![]()
Im doing the xp build just like yours with the double chain, what did the machine shop have to do to match the crank gear for the timing chain?
change the bevel.
If you bring both gears they should be able to figure it out.
You shouldn't.
But i think the machined pump cover might still be required.
Rollmaster and JP double roller timing sets were manufactured for the Australian 3800 crank's. As long as the crank gear key way chamfer, and cam gear are machined within proper offset tolerances of each other, you only need to double gasket to be golden. This is assuming, both gears are fully seated as they should be. The machined oil pump cover is only needed, if you improperly installed your timing set.
yea i planned on getting that done
check clearance for sure.
Hows traction? Id really like to see some incar pulls.
