Thread: AjL227's XP, S2 IC, 2.8" CompG build
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 113
  1. #1 AjL227's XP, S2 IC, 2.8" CompG build
    GTP Level Member AjL227's Avatar
    IL
    UPDATE 9/21/11: WHATS NEXT? UPCOMING
    SKIP AHEAD TO THIS THREAD FOR NEW POSTS
    >>>NEW UPCOMING PLANS<<<
    This thread is directed to my 2004 GP GTP CompG and it's modifications.
    I got this car with 7,xxx miles on the odometer, in February of 2007. It was all stock with Enkei 10 spoke alloy wheels.
    To this day, it has 68,xxx miles. This car is daily driven.
    -HPTuners Pro VCM suite
    -DHP
    -Comp Cam's X-P hot camshaft (212,224/.325.335/116LSA)
    -Rollmaster double roller timing set (properly machined)
    -105# valve springs
    -qwik port stock heads (casting #8)
    -ARP head studs
    -Cometic MLS .052" head gaskets
    -ZZP MPS 3.0"
    -ZZP 2.25" aluminum A2W intercooler system w/ silicone hoses & bosch pump (100% resealed/leak free)
    -ZZP billet fuel logs
    -Mototron 80#/hr (800cc) injectors
    -E85 (summer) / 93 octane (winter)
    -Poly upper engine mounts
    -ZZP billet aluminum upper engine supports
    -Poly lower engine mount
    -Poly transaxle mount
    -ZZP stainless headers
    -ZZP 3" 304SS downpipe
    -ZZP 3" 304SS catback exhaust
    -30" 304SS Magnaflow resonator
    -KYB GR-2 gas shocks
    -SSC lowering springs w/ anti-pogo washers
    -GXP brakes
    -Xenon HIDs 10,000k
    -Aeroforce scan gauge
    -AEM vac/boost
    -AEM wideband o2
    -AEM fuel pressure
    Progress:
    In-car tear down
    Engine is out
    Cam install
    Block, heads and timing set
    Valvetrain, front cover and intake
    Money shots
    Engine is in, and buttoned up
    Gas shocks, lowering springs & GXP brakes
    85mm LQ4 MAF & Mototron 80#/hr injectors
    ZZP I/C overhaul...new core, plates resealed, new hoses
    3.0" pulley IDLE VIDEO
    12 second pass, 110+ MPH @ GREAT LAKES DRAGWAY
    NEW UPCOMING PLANS
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  2. #2 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    Damn, sounds like you got a long way ahead of you my man.
    Best of luck!
    P.S. I like your grill yo, you do that yourself?
  3. #3 Re: AjL227's XP, S2 IC, 2.8" CompG build
    why are you changing the head gaskets when there are no heads on your list?
    Also why such a small cam?
  4. #4 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Your not going to get away with a 3.4" to a 2.8" by just adding a cam and injectors...MAYBE a 3.0". It's a GenV car guy...a 2.8" on a GenIII is a XP/IC/Injector/Header/Tuned car...like I said...your looking at a 3.0"-3.2" area.
  5. #5 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Jun 2010
    Illinois.
    Fauk, I know nothing about GTP's.
  6. #6 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Quote Originally Posted by Koniig View Post
    Let me google that for you
  7. #7 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Jun 2010
    Illinois.
    Oh GAWWD.
    Not lmgtfy. plx.
  8. #8 Re: AjL227's XP, S2 IC, 2.8" CompG build
    DO it.
  9. #9 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Jun 2010
    Illinois.
    it said "Walrus"??
    Here you go.
  10. #10 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Jun 2010
    Illinois.
    ITS A ****ING PARADOX!
    Blue why did you DIVIDE BY ZERO!?
  11. #11 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Ummm...what. Click the link I posted.
    It's the link to my Safely Modding Thread...but just incase.
    http://www.grandprixforums.net/safel...car-17482.html
  12. #12 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Jun 2010
    Illinois.
    Nvmd lol.
    It was a joke. ^_^
  13. #13 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Interwebz r 2 suriuuzz
  14. #14 Re: AjL227's XP, S2 IC, 2.8" CompG build
    utah
    Inj and pump are the best things on that list. Cuz the factory inj and pump crap out at 281whp....trust me :/ gonna be sick though man and I too love the grilss. How'd u do em?
  15. #15 Re: AjL227's XP, S2 IC, 2.8" CompG build
    IL
    I painted the chrome grills black, went around the edges in red, and finished with clear coat. I'm going for cometic head gaskets, because I trust them and I don't mind paying the extra $. I'm staying with stock heads, and running an XP because this is a daily driven car...
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  16. #16 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Then dont change the head gaskets.
    waste of money.
  17. #17 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Stock heads...stock head gaskets...hell even I am running stock Felpro's with my hogged out heads.
    I've seen and heard of a few vacuum leak issues with the MLS gaskets not sealing properly. Just get the Felpros...if you want to bump compression a tad...which is what your doing by getting a thinner gasket...have the heads or block milled a smidge.
  18. #18 Re: AjL227's XP, S2 IC, 2.8" CompG build
    GT Level Member sic6's Avatar
    san marcos, tx
    Since your head gasket is leaking i would also go for the fel pro's.
  19. #19 Re: AjL227's XP, S2 IC, 2.8" CompG build
    I'd like to know how and where the head gasket is leaking and what you've done to confirm your suspicions.
    Simply because head gaskets dont seem to be common at all on 3800's.
  20. #20 Re: AjL227's XP, S2 IC, 2.8" CompG build
    Donating User Odi's Avatar
    Chicago South Suburbs
    no need to change head gaskets... if youre not doing heads. lololololol.
  1. Are the compg gtp's faster than the non compg gtp's?
    By GMCARS4LIFE in forum Off Topic Discussion
    Last Post: 03-07-2011, 09:19 PM
  2. Turbo Build "UPDATED 12/22/2010"
    By bbptech in forum Turbo
    Last Post: 12-22-2010, 12:06 PM
  3. 04 CompG from MN here, Hello!
    By chili in forum Introductions/Noob Questions
    Last Post: 06-06-2009, 05:15 AM
  4. My CompG
    By RKELC in forum Visual/Body Modifications
    Last Post: 04-29-2008, 06:57 PM
