Block and heads have been primer'd and painted black. Block is ARP studded, and Cometic MLS .052" gasket'd for the 'qwik' ported heads. Rollmaster double roller timing set has been machined to fit the US 3800 crank keyway, and is installed. Balance shaft has been removed, will be JB welding the oiling for it, once the flex plate and rear cover come off.
