Quote Originally Posted by GR8racingfool View Post
Is that ARP assembly lube all over your cam shaft?
You install your new oil pan gasket dry, or did you add RTV on either side of it?
Yes, that is ARP assembly lube on the XP. The oil pan gasket was RTV'd all the way around, after the windage tray was modified to allow more oil return to the sump.
