Thread: problems removing crank bolt from hub
Results 1 to 20 of 25
  1. #1 problems removing crank bolt from hub
    Chicagoland
    hey guys I'm having trouble removing the crank bolt from the hub and I don't want to damage anything? How did you guys do this? Thanks.
    1997 Grand Prix GTP (Daily Driver) 2000 Camaro SS (Ma Toy).
  2. #2 Re: problems removing crank bolt from hub
    Outer Space
    I put an extension in one of the flywheel holes to keep it from moving while I used a breaker bar on crank bolt.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: problems removing crank bolt from hub
    vice grips on the flex plate and an impact worth its weight in steel.
  4. #4 Re: problems removing crank bolt from hub
    Chicagoland
    Well I can't find anything to latch on to and I don't see anything behind this hub. All I'm trying to do is replace the CPS and from what I read I have to take this god damn crank bolt off then I can use the puller to take of the pulley/hub
    But the problem is that I don't see a flexplate all that's behind it is NOTHING. I can't wedge anything around it, I've tried hot wrenching it and it won't budge.
    I'm just lost at this point, I'm starting this huge hub in the face and see no flex plate behind it or flywheel for that matter. Looks like those are on the otherside. Right behind this hub is the oil pan.
  5. #5 Re: problems removing crank bolt from hub
    the flex plate is between the motor and transmission. there are a couple inspection covers you have to take off.
  6. #6 Re: problems removing crank bolt from hub
    Outer Space
    So it sounds like the engine is still in the car. Air would probably be the safest and best bet.
  7. #7 Re: problems removing crank bolt from hub
    A breaker bar as worked every time for me...
    Its more difficult to torque it back to spec than it is to get it off.
  8. #8 Re: problems removing crank bolt from hub
    Apr 2009
    stockton ca
    starter trick/kick
  9. #9 Re: problems removing crank bolt from hub
    Florida
    You need to keep the flex plate from moving, theres a little plastic cover over it (like bio said between the trans. and motor) I've always done it with a pair of vicegrips, works great.
    Also, you're gonna need quite a bit of leverage if you're doing it by hand. When I did mine i used a 1/2 breaker bar that's 3ft long, with a 2ft extension on that, and it was still a *****.
  10. #10 Re: problems removing crank bolt from hub
    Charles City, IA
    SMGPFC Two Nipple General
  11. #11 Re: problems removing crank bolt from hub
    Chicagoland
    Alright thanks guys, I'm going to try it that way tomorrow. I made an appointment for the car to go in on Monday, but it doesn't hurt to give it one last shot before then. I'd love to save the money by doing it myself as well.
    Thanks again.
  12. #12 Re: problems removing crank bolt from hub
    SE Level Member pman64's Avatar
    Central Illinois
    The crank bolt uses a 24mm head. Use an impact. Good luck getting a puller in there, its a b*&ch.
  13. #13 Re: problems removing crank bolt from hub
    crank bolt is standard.
    its 15/16's.
    Puller fits fine.
  14. #14 Re: problems removing crank bolt from hub
    Jul 2008
    Fishkill, NY
    Put a box wrench on the nut and rest the open end of the wrench forward of the bolt on the cradle. Get in the car and blip the starter but don't start the engine. The torque of the starter will break that bolt free like it's not even there.
  15. #15 Re: problems removing crank bolt from hub
    Minnesota
    HEAT IT! I can't believe nobody has suggested this yet. The red s&*t on the inside of the crank bolt is probably holding it on. Heat it up and use either a braker bar or even better an impact. I had to heat then try it with the impact then heat then impact but it came off eventually. If you don't have an impact its going to be that much harder but use heat either way.
  16. #16 Re: problems removing crank bolt from hub
    Charles City, IA
    Quote Originally Posted by Pure2sin View Post
    Heat will melt the rubber in the balancer.
  17. #17 Re: problems removing crank bolt from hub
    Minnesota
    What rubber? I guess when I did my top swap I was just replacing my harmonic balancer with another one I didn't heat, but where is there rubber on the balancer? Only thing I would be worried about is possibly melting the crank seal maybe but hmm I guess I am confused about melting the balancer? All the guys I have talked to and my myself used heat to get it off. I am not talking about getting it RED hot but just enough to loosen the red stuff on the flange of the crank bolt.
  18. #18 Re: problems removing crank bolt from hub
  19. #19 Re: problems removing crank bolt from hub
    Minnesota
    So don't use heat on harmonic balancers?
  20. #20 Re: problems removing crank bolt from hub
  1. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  2. having problems removing water pump on 1999 grand prix gt 3.8L, series 2
    By RyanGerner in forum Introductions/Noob Questions
    Last Post: 08-17-2010, 09:30 PM
  3. Removing Crank Pulley
    By Poil336 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2010, 12:57 PM
  4. HELP! Can't remove crank pulley bolt!!!
    By Billy Low in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:06 PM
  5. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
