Thread: problems removing crank bolt from hub
Results 1 to 20 of 25
  1. #1 Re: problems removing crank bolt from hub
    vice grips on the flex plate and an impact worth its weight in steel.
  2. #2 Re: problems removing crank bolt from hub
    Chicagoland
    Well I can't find anything to latch on to and I don't see anything behind this hub. All I'm trying to do is replace the CPS and from what I read I have to take this god damn crank bolt off then I can use the puller to take of the pulley/hub
    But the problem is that I don't see a flexplate all that's behind it is NOTHING. I can't wedge anything around it, I've tried hot wrenching it and it won't budge.
    I'm just lost at this point, I'm starting this huge hub in the face and see no flex plate behind it or flywheel for that matter. Looks like those are on the otherside. Right behind this hub is the oil pan.
    1997 Grand Prix GTP (Daily Driver) 2000 Camaro SS (Ma Toy).
  1. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  2. having problems removing water pump on 1999 grand prix gt 3.8L, series 2
    By RyanGerner in forum Introductions/Noob Questions
    Last Post: 08-17-2010, 09:30 PM
  3. Removing Crank Pulley
    By Poil336 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2010, 12:57 PM
  4. HELP! Can't remove crank pulley bolt!!!
    By Billy Low in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:06 PM
  5. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
