Thread: problems removing crank bolt from hub
Results 1 to 20 of 25
  1. #1 Re: problems removing crank bolt from hub
    Minnesota
    HEAT IT! I can't believe nobody has suggested this yet. The red s&*t on the inside of the crank bolt is probably holding it on. Heat it up and use either a braker bar or even better an impact. I had to heat then try it with the impact then heat then impact but it came off eventually. If you don't have an impact its going to be that much harder but use heat either way.
  2. #2 Re: problems removing crank bolt from hub
    Charles City, IA
    Quote Originally Posted by Pure2sin View Post
    Heat will melt the rubber in the balancer.
    SMGPFC Two Nipple General
  1. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  2. having problems removing water pump on 1999 grand prix gt 3.8L, series 2
    By RyanGerner in forum Introductions/Noob Questions
    Last Post: 08-17-2010, 09:30 PM
  3. Removing Crank Pulley
    By Poil336 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2010, 12:57 PM
  4. HELP! Can't remove crank pulley bolt!!!
    By Billy Low in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:06 PM
  5. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
