I dont see 100 percent wot anywhere on that scan. I see 80 percent either Your TPS is reading wrong or you didnt go WOT. Replace the TPS and check to make sure the Throttle body cable is pulling the TB the whole way open. Also you are lean, Add 3 percent fueling to the 7,250 to 11,500 HZ Remember to add 2.5 to 7KhZ 2 percent to 6,750. 1.5 percent to 6,500 and so forth so it doesnt create a spike
