Thread: Getting knock w/ 3.4 pulley & All suported mods
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: Getting knock w/ 3.4 pulley & All suported mods
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    How do i check the rail pressure? I was cleaning my engine bay the other day and everything looked good and i don't have any type of leaks or anything. Yes i am running a stock 2004 monte carlo bin tune.
    Also would running seafoam in my gas tank cause my fueling to be like that. I filled up monday night on my way to work and added seafoam in to clean out my injectors. I am still running that gas even during the scans. I filled up w/ 93.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #22 Re: Getting knock w/ 3.4 pulley & All suported mods
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    No that should be fine. You need to add fueling to the 7K HZ-11,500 hz range. And alot of it. If i had to toss a number id say 8-9 percent. Check fuel pressure at the schrader valve
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #23 Re: Getting knock w/ 3.4 pulley & All suported mods
    Bowie, MD
    Quote Originally Posted by 01gpgt01 View Post
    Okay. Thanks gpg. Could you point me to the schrader valve?
  4. #24 Re: Getting knock w/ 3.4 pulley & All suported mods
    Quote Originally Posted by shawngtp View Post
    torque managment is doin it. Listen to bio ^^
    apparently torque management just takes the timing out directly and doesnt show up as KR.
    schrader valve has a black cap on it and its located on the fuel rail. Twists off.
  5. #25 Re: Getting knock w/ 3.4 pulley & All suported mods
    Bowie, MD
    Thanks matt. Would i need some special tool to check the pressure?
  6. #26 Re: Getting knock w/ 3.4 pulley & All suported mods
    yeah, parts store should have a fuel pressure testing kit.
    its cheapish.
    Note IGN V isn't your timing in those scans you posted. Not sure if you noticed that.
  7. #27 Re: Getting knock w/ 3.4 pulley & All suported mods
    kinda. i was seeing 'false' knock retard because of it pulling timing at shifts. just a little bit though.
  8. #28 Re: Getting knock w/ 3.4 pulley & All suported mods
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    also, 3* is not a lot, even on a 3.4 pulley.
    What's acceptable on a 3.4 pulley?
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  9. #29 Re: Getting knock w/ 3.4 pulley & All suported mods
    Timing retard from torque management will not be in the form of knock retard.
    Knock retard is exactly what the name says, timing retarded from the presence (or if you believe in false knock, perceived presence) of knock by the pcm and knock sensors.
    @OP... Burn up a tank of gas and get the SeaFoam out of it.. Then start your scanning for tuning. I doubt you will be running SeaFoam every day you drive in the future..
  10. #30 Re: Getting knock w/ 3.4 pulley & All suported mods
    Hagerstown,Md
    Quote Originally Posted by SliceTheRice View Post
    In short None. THE OP's issue is the fueling is WAY lean
  1. Knock because of crank pulley or fuel pump
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2009, 10:27 AM
  2. smallest S/C pulley with no other mods
    By millfire517 in forum General Tech Discussion
    Last Post: 02-20-2009, 03:04 PM
  3. new mods with knock or no?
    Last Post: 11-24-2008, 09:59 PM
  4. new mods with knock or no?
    Last Post: 11-23-2008, 07:13 PM
  5. could i run a 3.4 pulley with these mods?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2008, 03:17 PM
