Thread: Getting knock w/ 3.4 pulley & All suported mods
Results 1 to 20 of 30
  1. #1 Re: Getting knock w/ 3.4 pulley & All suported mods
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    I have a DHP tuner. So i basically have to tune my torque management? Should i tune myself or get an intense tune and start from there and modify the bin as i add more mods?
    Post a scan on www.scandepot.net scan the following:
    Throttle position
    Boost PSI
    RPM
    Speed
    LFT's Long term
    O2 in MV
    Maf in HZ not Lb
    Timing
    Intake air temps
    Injector duty cycle
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  2. #2 Re: Getting knock w/ 3.4 pulley & All suported mods
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Quote Originally Posted by 01gpgt01 View Post
    Throttle position
    Boost PSI
    RPM
    Speed
    LFT's Long term
    O2 in MV
    Maf in HZ not Lb
    Timing
    Intake air temps
    Injector duty cycle
    I couldnt even find some of those to scan but here is my scan though. I think im going to do what 02grandprixiraqvet said and find someone with a 3.4 tune and modify it for my car. Maybe someone on the powertuner site can give me one. Do any of you guys have one i could have? Id appreciate it.
    october scan from gotit4cheap16 -- Scan Depot dot net
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  3. #3 Re: Getting knock w/ 3.4 pulley & All suported mods
    Hagerstown,Md
    That scan was pretty Useless with out knowing 02's,timing, And throttle position. But from what I see the pcms pulling fuel WOT and your trims are all over the place. Which isnt good. Your maf needs a good tune.. http://www.scandepot.net/viewscan.php?pk=5280 this is what you want your scan to look like. If I were you I would learn how to scan and tune. It will only help you in the long run. Load in the correct pids and post another scan For your reference http://wiki.opentuner3800.com/index....et_a_Good_Scan Ignore the VE tune all together its worthless
  4. #4 Re: Getting knock w/ 3.4 pulley & All suported mods
    Jan 1970
    Maquoketa, Iowa
    I wouldn't get another file off of a random car. If anything, use a dhp 1.0 you can get off the powrtuner website until you learn how to scan and tune properly yourself. Make your own tune so you know whats changing or has changed.
    I would download UvScan to scan. Then Eddies table modifier to do a bunch of maf tuning. Make small changes each time and flash it with powrtuner. Make sure to save the files in order so you can always go back to something if you don't like that change.
  1. Knock because of crank pulley or fuel pump
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2009, 10:27 AM
  2. smallest S/C pulley with no other mods
    By millfire517 in forum General Tech Discussion
    Last Post: 02-20-2009, 03:04 PM
  3. new mods with knock or no?
    Last Post: 11-24-2008, 09:59 PM
  4. new mods with knock or no?
    Last Post: 11-23-2008, 07:13 PM
  5. could i run a 3.4 pulley with these mods?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2008, 03:17 PM
