Thread: 8psi with a 3.2 normal???
Page 1 of 3 123 LastLast
Results 1 to 20 of 56
  1. #1 8psi with a 3.2 normal???
    SE Level Member Justin48's Avatar
    Groton, CT
    Hey so i have a:
    02 gtp 54,000miles
    xp cam
    speed daddy headders
    prj intercooler
    fwi
    3.2 zzp mps
    3.5 oversided tensioner pully...
    at wot aeroforce says i am only pushing 8psi at sea level, is that normal?
    friend of mine has
    97 gtp 150,000miles
    xp cam
    plog
    3" catless dp
    stainless back cut valves
    k&n intake
    3.2 press on
    and he is running 11psi sea level...
  2. #2 Re: 8psi with a 3.2 normal???
    Willoughby, Ohio
    he should have more boost since you are flowing better with your headers, but as far as numbers go someone who is more knowlagable will chime in to help
  3. #3 Re: 8psi with a 3.2 normal???
    Your intercooler and headers are keeping your boost levels lower...if you want higher boost numbers...put on a smaller pulley and supporting mods...which...with an IC and XP...you should be running at least a 2.8" on there.
  4. #4 Re: 8psi with a 3.2 normal???
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    Headers and Cams will both drop boost levels compared to a car without. I can't say for sure on how much it should have as I don't have a blower car.
    Retired
    Turbo'd
  5. #5 Re: 8psi with a 3.2 normal???
    Groton, CT
    wow 2.8!!! i was told that a 3.0 was about limited... my total list of mods are
    fwi
    180*
    autolite 104
    prj intercooler
    zzp stage 3 fmic
    bosh ic pump
    130#springs
    modded retainers
    comp cams keepers
    double roller chain
    machined oil pump cover
    42.5 injectors
    speed daddy headers
    hp tuners
    performance shift added
    wide band o2
    aeroforce
    3.2, 3.4 mps
    think thats a full list...
  6. #6 Re: 8psi with a 3.2 normal???
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    So which would is faster? His car or his friends car with more boost?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  7. #7 Re: 8psi with a 3.2 normal???
    one with less boost will be faster.
    its flowing better.
    And I want your PRJ core.... lmao
    You should also consider porting your blower or having that done and a larger TB be it a ported stock or say an LS1 or N*.
    Might want to also consider a colder plug, those might be too hot for you if you do decide to hit the 2.8-3 region.
  8. #8 Re: 8psi with a 3.2 normal???
    Groton, CT
    well i have a set of 304's new in box... sorry i am quite happy with my core... was thinking of doing a port job but would like to see about finding a gen III in a junk yard or something and doing a port job on it... and guess look for a N* while at it... oh the answer to the whos faster did a run from 30-145 and we kinda just keep "nosing* in front of the other... mind you he has a zzp pcm with parameters in it he wanted for his mods.. and my pcm is a "tweaked" tune from paul at prj with a "ballpark" injector correction... i haven't even dialed it in (scared to at the moment but still researching it...) and from a dig we both punched too hard and broke loose but both hooked up right away and STILL ended up at 120 and ended up letting up... he was glad to finally race some one that actually was a "good race" lol...
    oh do you need to "shave the snout" for a 2.8? zzp says anything smaller than a 2.8 but didn't know if that ment 2.8 and under...
  9. #9 Re: 8psi with a 3.2 normal???
    MA
    i think reptile has some cores, you could have him port for you and then send him yours.
    you can contact him on here
    SMGPFC Member #9
  10. #10 Re: 8psi with a 3.2 normal???
    Topeka, KS
    Reptile ported my SC and TB and did a wonderful job. Killed my knock on my 3.4 setup too... Throttle response really picked up with those mods!
  11. #11 Re: 8psi with a 3.2 normal???
    And for your throttle body choice...N*'s pedal feel is crap in comparision to a LS1...the N* was too jumpy...I love my LS1...its as smooth as stock was...just some little info for ya.
  12. #12 Re: 8psi with a 3.2 normal???
    2.8 works fine.
    any smaller needs machining, but you should never run a pulley that small. You'd be doing more harm than good.
    Basically if you need to go smaller you need a larger/more efficient blower.
  13. #13 Re: 8psi with a 3.2 normal???
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    More timing>then more boost. What kind of timing and knock levels are you seeing on your car? Whats your AFR. If you can run a 11.8ish AFR and 19 wot with no knock then drop lower and see what it does. Id think a 3.0 with 19 wot timing would suit you well.
    You should also add a Fuel pump rewire in there to aviod drop off on say a 1/4 mile run. FWIW I was seieng 7 psi on a 3.4 intercooled Header set up. so your 3.2 with your cam Ect seems good. Boost= A mesurement of restriction. The better you flow the less the boost and also the lower the heat.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  14. #14 Re: 8psi with a 3.2 normal???
    Groton, CT
    Hey thanks for the word on the LS1 tb... good things to know yeah ill look into reptile on the blower porting.. do people do any port jobs on the ls1 tb's? or is the stock size the limit? right now i dont know what timeing is i am at work but ill look it up but my wb 02 pegs rich at wot around 10.0 dont think it will go any lower lol and i have no kr... hey do 02's have a problem with removal of the tb's "honeycomb" my buddys 97 started throwing codes and haveing issues with it removed.. ill do a few runs and scan it mind you the wb would not be in the scan being i dont have the "pro" hp tuners...
  15. #15 Re: 8psi with a 3.2 normal???
    I live here. TLSheff's Avatar
    Quote Originally Posted by 01gpgt01 View Post
    More timing>then more boost... ...Boost= A mesurement of restriction. The better you flow the less the boost and also the lower the heat.
    Alot of people forget or don't understand the principles on boosting cars. High psi figures don't really mean much. What you want to achieve is a high CFM amount going into the intake, which is where the lower pulley comes in. The supporting mods are so the engine can allow it to handle the amount of air coming in, and the flow allows it to be able to escape without building up pressure and launching your heads off the car like a NASA space rocket.
  16. #16 Re: 8psi with a 3.2 normal???
    you should be around 11.5-12, not 10....
  17. #17 Re: 8psi with a 3.2 normal???
    Hagerstown,Md
    Quote Originally Posted by Justin48 View Post
    Wow you tune your car and you dont know the Ignition timing and allow it to run on a 10.0 afr? You need to lean that thing out and see what the sparks at. (see what spark is first)You will gain a crap ton from just leaning. Post up some scans.
  18. #18 Re: 8psi with a 3.2 normal???
    Groton, CT
    hey well i will do some scans tonight. the "tune" i have is a prj tune and all i changed was the injector size and the shift tables and the fans... i haven't studied enough on how to do a proper spark/fueling tune... i did the install of the parts got it running and drove it back to San Diego from Washington state and just haven't had the time to read on the "major" dial in.. i know its a little lazy but any one know the link some one had running around here for "tapping in" the egr harness to get the wideband to register on vcm scanner? just for temporary for tuning purposes
  19. #19 Re: 8psi with a 3.2 normal???
    Charles City, IA
    Go into my profile and look at threads I created. It is one of them.
    SMGPFC Two Nipple General
  20. #20 Re: 8psi with a 3.2 normal???
    Groton, CT
    drive from Coronado to imperial beach
    coronado-ib from justin48 -- Scan Depot dot net
    drive from imperial beach to chula vista
    ib-chula vista from justin48 -- Scan Depot dot net
    drive from chula vista to Coronado
    chula vista-coronado from justin48 -- Scan Depot dot net
    sorry mods if this is starting to become a tuning thread...
  1. Is this normal?
    By 2001GTP in forum General Tech Discussion
    Last Post: 01-11-2010, 08:10 AM
  2. Is this normal
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2009, 11:19 PM
  3. Can i use normal Paint
    By shawnz90 in forum Visual/Body Modifications
    Last Post: 10-06-2009, 08:58 PM
  4. Normal Oil smell?
    By xerxescct in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 10:45 PM
  5. HID flickering... is this normal?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 06-29-2009, 09:15 AM
