Thread: 8psi with a 3.2 normal???
Results 1 to 20 of 56
Threaded View
  1. #11 Re: 8psi with a 3.2 normal???
    I live here. TLSheff's Avatar
    Quote Originally Posted by 01gpgt01 View Post
    More timing>then more boost... ...Boost= A mesurement of restriction. The better you flow the less the boost and also the lower the heat.
    Alot of people forget or don't understand the principles on boosting cars. High psi figures don't really mean much. What you want to achieve is a high CFM amount going into the intake, which is where the lower pulley comes in. The supporting mods are so the engine can allow it to handle the amount of air coming in, and the flow allows it to be able to escape without building up pressure and launching your heads off the car like a NASA space rocket.
  1. Is this normal?
    By 2001GTP in forum General Tech Discussion
    Last Post: 01-11-2010, 08:10 AM
  2. Is this normal
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2009, 11:19 PM
  3. Can i use normal Paint
    By shawnz90 in forum Visual/Body Modifications
    Last Post: 10-06-2009, 08:58 PM
  4. Normal Oil smell?
    By xerxescct in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 10:45 PM
  5. HID flickering... is this normal?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 06-29-2009, 09:15 AM
