Your 02's look low, Im highly suspect of your 10.0 AFR wot. Your timing is way low. Are you sure your W/b is reading proper? Id personally bump up 7-11500 Hz 2 percent and bump up the timing to 17-18. But first you need to check your wideband and whats going on with that. Missed matts post, But yeah I pretty much Mirrored what he said. With timing that low your EGT's skyrocket quick. Which isnt good. Im sure your car also feels like it bogs down quite a bit. Uping the timing will help with that, but first we need to confirm your fueling.
