Thread: DNA Headers + Coolant Fans Problem
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 DNA Headers + Coolant Fans Problem
    Largo, Florida, United States
    Anyone got the First gen of the DNA Headers (SSAC K/O) ones
    and Had any Coolant Fan problems?
    My issue from the looks of it.
    DNA Headers Pushed Adginst Heatsheild which pushed Fan into Radiatior
    Since the fan couldn't move The Fan Motor Blew
    So I'm thinking as a Fix get the Flat Heatshield that the Passenger Side fan has and switch em out? and replace the fan motor OR Rock no Heat Shield on the fan? (would the Temp from the Headers kill it?
  2. #2 Re: DNA Headers + Coolant Fans Problem
    Man all these problems recently...that must suck.
  3. #3 Re: DNA Headers + Coolant Fans Problem
    Yeah. you guys don't know the half of it since i got to Miami
    First my lower Radiator Hose Was TWISTED and the SC belt ripped a nice hole in it. Drained all my coolant almost Overheated my car. I parked once i saw the temp going up.
    fixed it in a Gas station parking lot after a trip to Napa, Thank god i brought my Mini set of tools!
    Then I couldnt get to the 2nd Clamp under the coil packs to get it off. Finally got to it. put it back together and drove a few miles But it was STILL over heating!?
    Parked it slept overnight in my car outside of work (since i hadnt gotten my room in miami yet paid for by the govt)
    Then I Determined it could be the Theomostat replaced that and the gasket
    It was Still overheating just took Alot longer and then i noticed the Driver side fan wasnt kicking on
    then i noticed it was being pushed ON the Radiator.
    SOOOOO I'm getting to the Root of the Problem...
  4. #4 Re: DNA Headers + Coolant Fans Problem
    to be honest, my headers leaned up against my radiator fan heat shields as well and i ran headers for two years or so.
  5. #5 Re: DNA Headers + Coolant Fans Problem
    Banned - Busted For Scamming
    Feb 2009
    dont have this problem with my obx...
  6. #6 Re: DNA Headers + Coolant Fans Problem
    Charles City, IA
    My SSAC do not hit.
    SMGPFC Two Nipple General
  7. #7 Re: DNA Headers + Coolant Fans Problem
    Jan 1970
    Maquoketa, Iowa
    Crowbar + Sawzall = Sexytime.
    Discard the heat shield, you don't have much more of an option. Take a drive until the engine warms up, then check the fans to see if they are hitting or rubbing still.
  8. #8 Re: DNA Headers + Coolant Fans Problem
    i had shortened dogbones, otherwise mine wouldnt have hit either.
  9. #9 Re: DNA Headers + Coolant Fans Problem
    GTX Level Member killakross5o4's Avatar
    illinois
    idk.. i think i am just going to say screw DNA and get real ssac
    Shortstack Intercooler, 1.9 Rockers, 3.2 pulley,180 drilled T stat,103 plugs, U bend delete with no cat, thrush resinator,3inch pace setter cat back,shift kit,ZZP Chrome tips,,ZZP stage 2 throttle body,homemade 4 inch CAI,DHP tuned PCM,SSAC headers
  10. #10 Re: DNA Headers + Coolant Fans Problem
    illinois
    forget trying to save a buck
  11. #11 Re: DNA Headers + Coolant Fans Problem
    Apr 2009
    stockton ca
    What i dont understand is Why cant they just make a decent bolt on product they have the materials and its easy to get some one in to do fab work for differnt makes of cars
    Oh well the real ssac's are the way to go i guess
  12. #12 Re: DNA Headers + Coolant Fans Problem
    yeah but i gotta see if i can grab the flat one from a passenger side GP from a junkyard
  13. #13 Re: DNA Headers + Coolant Fans Problem
    Jul 2008
    sumter,south carolina
    i have a quarter inch clearance at the closest distance between fans and headers (SSAC knock offs). My concern was heat on the fan motors...
    02 GTP with mods 05 GP for DD
  14. #14 Re: DNA Headers + Coolant Fans Problem
    SE Level Member geforcextreme's Avatar
    Holland Pa 18966
    When I installed my tog headers, had to remove the metal heat shield on one of the fans for the header to clear. After it was removed, perfect!
    2000 Buick Regal GSE Blown, Cammed, Intercooled, and pretty fast for a Grocery Getter - 320WHP
    Best Time June 9th 2009: 1/4 = 12.994 @ 107.82mph on Street Tires 2.118 60 Foot
  15. #15 Re: DNA Headers + Coolant Fans Problem
    Outer Space
    My pacecrappers don't hit.
    02 GTP 13.6 @ 100mph - SOLD
  16. #16 Re: DNA Headers + Coolant Fans Problem
    so i'm assuming its safe to remove the heatshield with the headers being that close?
  17. #17 Re: DNA Headers + Coolant Fans Problem
    Quote Originally Posted by Lawngoose View Post
    Mine don't either. Must be a design flaw
  18. #18 Re: DNA Headers + Coolant Fans Problem
    West Side Michigan
    Yea does anything happen if you remove the shield? Or is it pretty much useless and can be discarded?
  19. #19 Re: DNA Headers + Coolant Fans Problem
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    i wouldnt remove it. its ther to keep the heat away from the fan motor to extend the life of the fan. when removed its just gona shorten life of the fan
  20. #20 Re: DNA Headers + Coolant Fans Problem
    GT Level Member Joe m's Avatar
    mesa,az
    even the real ssac's haver issues that have to be fixed. my rear o2 is pushed into my body of the car. which is causing i notacble vibration when i start and drive. i think only weay to fix it is to cut the peice and twist it. oh and the damn ubend in the ssac's i didnt have tme to fix mine last night. and it drags over any little bump i have in my yard lol. if i was to run with no rear o2 till i got it tuned what would happen?
  1. coolant fans only work when A/C is on
    By bigwillie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-26-2011, 07:14 PM
  2. Supercharger Oil + Coolant Mega-problem
    By element55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2009, 05:43 PM
  3. Shift Interlock Problem & Coolant Gauge Problems
    By 98GTPON22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2009, 04:02 PM
  4. Heat/fans problem getting worse
    By Freebeer187 in forum General Tech Discussion
    Last Post: 01-11-2009, 06:38 PM
  5. Coolant Elbow Problem
    By Abrasive in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 08:39 AM
