Thread: Supercharger and cam questions
Results 1 to 5 of 5
  1. #1 Supercharger and cam questions
    SE Level Member basshead42's Avatar
    Toledo, OH
    I have a 2000 gtx....i wanna buy a spare supercharger to pollish and was wondering if all the m90's on the 97-03 are the same. For instance will a supercharger off a 98 match up to my LIM? Also i eventually want to get a cam and someone informed me that if i do, the engine will only last 20,000 miles and Ill be eating up timing chains. Is that true? Thanks guys
    2000 GTX--3.4 pulley, MSD wires, NGK Iridium plugs 2 ranges colder, 180* Tstat, U-Bend delete, DHP 1.0 PCM, Ram-Air, headers are next!
  2. #2 Re: Supercharger and cam questions
    swift current,sask.
    Yes as far as i know all of the gen 3 m90's are exactly the same. If you do a cam yes, you will see a bit more wear on the valvetrain because of the bigger spring's you are going to be putting in. You should be able to get a lot more miles out of it than 20000.
  3. #3 Re: Supercharger and cam questions
    Banned - Busted For Scamming
    Feb 2009
  4. #4 Re: Supercharger and cam questions
    Charles City, IA
    Quote Originally Posted by basshead42 View Post
    It will eat chains if you can not install them right. People have beaten the hell out of their cammed car for 30k+ and not have an issue. If you build something right it will run for a long time.
    SMGPFC Two Nipple General
  5. #5 Re: Supercharger and cam questions
    I beat the living GOD out of my XP'd car with a stock chain and dampner. Now that I've got a stupid cam going in I upgraded to a Rollmaster Double Roller...with the crank gear matching the stock one in height. As long as you have the right springs/retainers/chain setup...you should be fine
  1. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  2. 1997 supercharger questions
    By skidoojames151 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 12:37 AM
  3. Supercharger noise and questions
    By DMohr87 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:11 PM
  4. Motor questions, installing a supercharger
    By dirtracer007 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-06-2008, 04:37 PM
