ok but it'll be lkong and drawn out since rotating assembly geometry plays a huge part in how and where peak cylinder pressure occurs (which ideally would be at around 30* ATDC)
Okay, Im kinda glad you dropped in because I was unsure if the ideal timing was at 0* or after, but that helps.
So we would want spark to occur say at 0* and maximum pressure build at 30* ATDC for example, correct?
