Thread: Engine Guru's, Help Me Understand Ignition Timing
Results 1 to 20 of 27
  1. #1 Re: Engine Guru's, Help Me Understand Ignition Timing
    Saraland Alabama
    yes, but it's still not a ton of variance (mechanical advance was only about 5* wasn't it?)
  2. #2 Re: Engine Guru's, Help Me Understand Ignition Timing
    hangover park IL, in the garage working on one of 12 3800's
    Quote Originally Posted by archemedes View Post
    when the engine is at 6000 rpm its a ton of variance remember the speed at which the mixture ignites is dep on the fuel quality (VOC's, rapid vaporization, R or M octane rating etc.
    then you have to take into account the mixture...is it a homogenous mixture near the plug, has the cylinder fill event occured where fuel is actually near the cylinder walls or concentrated near the spark plug.
    the big biys have been playing with wet flow benches for a while now...look at the huge jumps in cylinder head/port/chamber design in just the last 5 years
  1. MSD Ignition Coils
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2008, 10:18 AM
  2. Ignition Problem.
    By dbean in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 07:49 PM
  3. Key stuck in ignition-
    By checkm8gtp in forum General Tech Discussion
    Last Post: 02-21-2008, 07:46 PM
  4. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
