Thread: Engine Guru's, Help Me Understand Ignition Timing
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #1 Re: Engine Guru's, Help Me Understand Ignition Timing
    Hoffman/Schaumburg, IL
    ^^^ What if you ran a gaseous fuel like propane?
  2. #2 Re: Engine Guru's, Help Me Understand Ignition Timing
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    I suppose you could use a different injector that has a better nozzle designed to promote more atomization but I have never seen anything like that available for the GP.
    ....so find the injectors that will do what you want and need, and get some custom machined heads, man!!!
  3. #3 Re: Engine Guru's, Help Me Understand Ignition Timing
    Oklahoma
    I suppose that would work, but the expense and the extent of the modification needed to run that would be cost prohibitive to most. But what I have seen as solid possibilities would require very little modification and not a terrible amount of work.
    In fact, if I could find me a mechanically sound set of L32 heads that needed nothing more than a good cleaning, I would work on trying a few things out. My Isuzu would probably be easier to work on in terms of simplicity, but I am more familiar with the 3800, as well the Isuzu is a 95 and I would not be able to hook up my laptop to it.
  4. #4 Re: Engine Guru's, Help Me Understand Ignition Timing
    Oklahoma
    LOL. yeah, its just that easy.
    Even if it were, I would still like to try a few of the other ideas Ive ran across on some L32 heads and see if there is any merit to them. Plus it would get me comfortable in pulling an engine down to the heads which I have never done before.
  5. #5 Re: Engine Guru's, Help Me Understand Ignition Timing
    SW Chicago Suburbs
    nevermind that custom heads such as those would likely be at least as much as you paid for your car, but hey, if you cant go big, go home
    its only money, right?
  6. #6 Re: Engine Guru's, Help Me Understand Ignition Timing
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    As far as better atomization goes do gas injectors even come close to the atomization of fuel compared to a diesel injector? We don't even come close the the fuel pressures of a diesel engine.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  7. #7 Re: Engine Guru's, Help Me Understand Ignition Timing
    I live here. UR LOSN's Avatar
    Rockford, IL
    This thread has been approved by me....lol
    Very well done James!!!!
  1. MSD Ignition Coils
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2008, 10:18 AM
  2. Ignition Problem.
    By dbean in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2008, 07:49 PM
  3. Key stuck in ignition-
    By checkm8gtp in forum General Tech Discussion
    Last Post: 02-21-2008, 07:46 PM
  4. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
