I fixed the problem. I replaced my resistor pack and everything worked great.. However changing the resistor pack was a pain in the ass. If your a big guy, you might want to pay a garage to change thr resistor pack. The rear top bolt is a major pain to take out. The trick is, just loosen the top rear bolt about 4-5 turns and just loosen the rear side bolt about 4-5 turns, but take the front bolt all the way out.. The resistor pack wil then slide out of the bolts, and then slide the new resistor pack back in... I had to pull my carpet out of the way, and and cut the floor rubber and insulation just to get my small socket/wrench to get the top rear bolt out. I also had to use a craftsman small mirror to guide my socket onto the bolt because you are unable to see the bolt head.. Let's say that this small job took alot longer than expected and I was pissed of the whol time.. Plan on spending your time laying on your back and shoulders.. I will not do this job again.. Have fun.![]()
