Thread: Need help with heater/ac control unit
Results 1 to 6 of 6
  1. #1 Re: Need help with heater/ac control unit
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    usually the blower resistor is at fault for the blower problem you describe. also its hard to guess what model car you have but im assuming its like an 01 gt.....check all fuses, seems something is wrong with the whole control unit. does seem strange that all things do not work except for number 5 on the blower switch.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  2. #2 Re: Need help with heater/ac control unit
    We've had three GTPs and a GT in the family and all have had this problem. They will replace the resistors for the blower but the real culprit on all of ours has been a power distribution block or something in the steering colum.
  1. Need help with HEATER/AC CONTROL PLZZZ???
    By Sameer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2009, 09:50 AM
  2. Heater/ac control
    By Sameer in forum How To Write-Ups/Tech Tips
    Last Post: 10-25-2009, 08:08 PM
  3. Heater Control
    By TMC in forum General Tech Discussion
    Last Post: 11-27-2008, 07:42 PM
  4. AC Heater Control Unit????
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 11-08-2008, 08:04 PM
