Thread: Need help with heater/ac control unit
Results 1 to 6 of 6
  1. #1 Re: Need help with heater/ac control unit
    Maryland
    My 2002 Grand Prix SE 3.1L has issues with the Fan Dial Knob. Blower motor doesn't blow air or heat while the Dial knob is at 1,2,3,4 but it does work only at the 5th dial knob position. Well for 3 months Dial knob stopped blowing on 1 & 2 dial setting, and 3,4,& 5 were fine. Now I lost all 1,2,3 & 4, but 5 dial knob setting works fine.. Would this be a Restistor Pack or Switch? Not sure where to start. Does anybody have ideas with my problem on my year and model car?
    All help is greatly appreciated..
    ~Thanks for your time in responding.
  2. #2 Re: Need help with heater/ac control unit
    PA
    Quote Originally Posted by pvensel View Post
    My 2002 Grand Prix SE 3.1L has issues with the Fan Dial Knob. Blower motor doesn't blow air or heat while the Dial knob is at 1,2,3,4 but it does work only at the 5th dial knob position. Well for 3 months Dial knob stopped blowing on 1 & 2 dial setting, and 3,4,& 5 were fine. Now I lost all 1,2,3 & 4, but 5 dial knob setting works fine.. Would this be a Restistor Pack or Switch? Not sure where to start. Does anybody have ideas with my problem on my year and model car? All help is greatly appreciated..~Thanks for your time in responding.
    I would start with the Blower motor resistor first. If that doesn't fix it, then the ignition switch.
    2001 GSE
  3. #3 Re: Need help with heater/ac control unit
    Maryland
    I fixed the problem. I replaced my resistor pack and everything worked great.. However changing the resistor pack was a pain in the ass. If your a big guy, you might want to pay a garage to change thr resistor pack. The rear top bolt is a major pain to take out. The trick is, just loosen the top rear bolt about 4-5 turns and just loosen the rear side bolt about 4-5 turns, but take the front bolt all the way out.. The resistor pack wil then slide out of the bolts, and then slide the new resistor pack back in... I had to pull my carpet out of the way, and and cut the floor rubber and insulation just to get my small socket/wrench to get the top rear bolt out. I also had to use a craftsman small mirror to guide my socket onto the bolt because you are unable to see the bolt head.. Let's say that this small job took alot longer than expected and I was pissed of the whol time.. Plan on spending your time laying on your back and shoulders.. I will not do this job again.. Have fun.
  1. Need help with HEATER/AC CONTROL PLZZZ???
    By Sameer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2009, 09:50 AM
  2. Heater/ac control
    By Sameer in forum How To Write-Ups/Tech Tips
    Last Post: 10-25-2009, 08:08 PM
  3. Heater Control
    By TMC in forum General Tech Discussion
    Last Post: 11-27-2008, 07:42 PM
  4. AC Heater Control Unit????
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 11-08-2008, 08:04 PM
