that would be a bad fuel pump causing the low pressure, would explain why it was cranking 10 times before it fired up the before vid you posted.
try beating on the bottom of the gas tank, see if the pressure goes up. if it does and then fires right up, you know the pump is bad. beating on the tank can shock it back to life. but its a temp fix at best.
where can i get a fuel pump cheap because I dont feel like putting alot into this car other than into motor as is is a doner car but will be my daily for a few months till i pull the motor
