that would be a bad fuel pump causing the low pressure, would explain why it was cranking 10 times before it fired up the before vid you posted.
try beating on the bottom of the gas tank, see if the pressure goes up. if it does and then fires right up, you know the pump is bad. beating on the tank can shock it back to life. but its a temp fix at best.
Oh okay well I think it took so many cranks bc scrappy battery and it was like -2°f out lol but it probably needs a new fuel pump too
