you leave the key to run for 10 minutes, then turn it off for less then 10 seconds, then on for 10 minutes again do this 3 times, then the 4 th time it should crank and run.
so thats key to run 3 times for 10 minutes, turn it off and then it should crank and run on the 4 th key turn. if your battery is weak run a battery charger or you can use jumper cables off a running car to keep your battery alive. you dont want to waste 30 minutes of life 2 times on this.
