Thread: Will not start after replcacing fuel rail and injectors
Results 1 to 20 of 136
  1. #1 Re: Will not start after replcacing fuel rail and injectors
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Well, it's a start! (no pun intended). Go ahead and rent or buy that fuel pressure tester and see what the pressure is. If it's just low and below 43, test the fuel pump for voltage and ground at the pump connector, if no pressure, then still test the connector for voltage. That way you can be sure you're actually replacing the issue and not parts swapping for no reason. There's a fuel pump resistor that can cause these symptoms. Just follow the steps
  2. #2 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Quote Originally Posted by wstefan20 View Post
    thats what I plan on doing thankyou
  3. #3 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    does auto and advanced auto not have fuel pressure gaug loaner tools anymore?
  4. #4 Re: Will not start after replcacing fuel rail and injectors
    Aug 2017
    Raytown, MO
    Quote Originally Posted by jetfighterv View Post
    Ones out here do. Might have to call ahead to see if they're out on rental
  5. #5 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    yea probably will
  6. #6 Re: Will not start after replcacing fuel rail and injectors
    So for the car to run and toggle the injectors, you need a couple of things.
    The PCM needs to see that the car is running. This is done with signals from the coil pack getting back to the PCM. Otherwise the PCM turns off the injectors. The injectors are then toggled on/off via the ground wires that go to them from the PCM. I have also seen a bad maf turn off fuel with the pcm thinking it had no airflow, so no fuel.
    There's not much that can do it though. I'm trying to load the up GM manuals to see the diagnostic aid.
  7. #7 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    okay thanks imma make a list of what ive done to check
    check plugs
    check plug
    test power to injectors
    put new old injectors back in then put new ones back after that didnt work
    tightern up the icm connector
    sprayed starter fluid (started with that)
    everytime i take fuel rail off it sprays fuel everywhere so its getting fuel to injectors for sure
  1. fuel rail/injectors
    By buschegt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2013, 02:58 PM
