Thread: Will not start after replcacing fuel rail and injectors
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 41 to 60 of 136
  1. #41 Re: Will not start after replcacing fuel rail and injectors
    sensor thats mounted on the back of the blower, one line runs to the gas tank, the other to the tb.
  2. #42 Re: Will not start after replcacing fuel rail and injectors
    Quote Originally Posted by jetfighterv View Post
    Yes I have unfortunately i havent been able to have anyone crank it while I spray
    take the intake off, then open the tb and spray right in there for like 5 seconds, then go crank it. if it fires right up and run for like 5 seconds or so your not getting fuel.
  3. #43 Re: Will not start after replcacing fuel rail and injectors
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Also, check to see if the connector on the front going to the crankshaft/camshaft sensors is plugged in all the way. I've had that happen. It's right by the evap solenoid (at least on n/a).
  4. #44 Re: Will not start after replcacing fuel rail and injectors
  5. #45 Re: Will not start after replcacing fuel rail and injectors
    Aug 2017
    Raytown, MO
    Thanks scotty. Yeah, the plug is by the fuel pressure regulator on your application and runs down to the crank sensor/cam sensor/front knock sensor.
    But yes, check all your vacuum lines. It still should start even with a big vacuum leak, but might as well check the routing.
  6. #46 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Quote Originally Posted by wstefan20 View Post
    okay so the t fitting before the map sensor is snapped off im pretty sure could that be why?
  7. #47 Re: Will not start after replcacing fuel rail and injectors
    Aug 2017
    Raytown, MO
    Hm. Definitely could be a factor. It would take a pretty large vacuum leak to cause a no-start, but I'd start with repairing that.
  8. #48 Re: Will not start after replcacing fuel rail and injectors
    T at the map? you mean under the snout? that t branches off to the map.
    if you got the old hard lines still replace them, if you got a advance auto near by pop in there, they got a wall of nothing buy vac t's y's you name it.
    they have a two pack of two small white T's, then new vac line is about a buck a foot, get like 5 foot you'll have extra. open the t pack, get a line that fits on it snug.
  9. #49 Re: Will not start after replcacing fuel rail and injectors
    this fat hose to a hard line is the evap off the tb.
    Will not start after replcacing fuel rail and injectors Attached Images
  10. #50 Re: Will not start after replcacing fuel rail and injectors
    Do me a favor.. check the connector going to the ICM. That the thing under the coil packs.
  11. #51 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Okay I will tomorrow
  12. #52 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Yes under the snout and yea it probably needs some new likes bad what size do I get tho
  13. #53 Re: Will not start after replcacing fuel rail and injectors
    they are tiny. like i said, pop the package open, tell they guy you want line that fits the T. you'll need to at least spit on the line for under the snout and work that one on, its a fat tube on the lim, but it will fit.
    you get two, you need em both, cut a inch or so of line off to put on the snout and fpr, then put the T in that line, then run the new lines.
  14. #54 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Okay will do
  15. #55 Re: Will not start after replcacing fuel rail and injectors
    Aug 2017
    Raytown, MO
    And Hey! It's a great excuse to throw together your own smoke machine like I did to verify the repair! Lol
  16. #56 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Link me to the thread! Lol
  17. #57 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Link me to the thread!! Lol
  18. #58 Re: Will not start after replcacing fuel rail and injectors
    Aug 2017
    Raytown, MO
    Best $30 I've spent in a long time! http://http://www.grandprixforums.co...uum-leaks.html
    If you don't have an air compressor, any air pump works in a pinch (mattress inflator etc.)
  19. #59 Re: Will not start after replcacing fuel rail and injectors
    FWIW, these engines will start and run with a monster leak like a vacuum booster being unhooked. Experience talking here. lol
  20. #60 Re: Will not start after replcacing fuel rail and injectors
    Aug 2017
    Raytown, MO
    lol that's what I was thinking too. I've had no problems starting with small leaks. Good to know bill!
  1. fuel rail/injectors
    By buschegt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2013, 02:58 PM
