Thread: Will not start after replcacing fuel rail and injectors
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 101 to 120 of 136
  1. #101 Re: Will not start after replcacing fuel rail and injectors
    So for the car to run and toggle the injectors, you need a couple of things.
    The PCM needs to see that the car is running. This is done with signals from the coil pack getting back to the PCM. Otherwise the PCM turns off the injectors. The injectors are then toggled on/off via the ground wires that go to them from the PCM. I have also seen a bad maf turn off fuel with the pcm thinking it had no airflow, so no fuel.
    There's not much that can do it though. I'm trying to load the up GM manuals to see the diagnostic aid.
  2. #102 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    okay thanks imma make a list of what ive done to check
    check plugs
    check plug
    test power to injectors
    put new old injectors back in then put new ones back after that didnt work
    tightern up the icm connector
    sprayed starter fluid (started with that)
    everytime i take fuel rail off it sprays fuel everywhere so its getting fuel to injectors for sure
  3. #103 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    that would be a bad fuel pump causing the low pressure, would explain why it was cranking 10 times before it fired up the before vid you posted.
    try beating on the bottom of the gas tank, see if the pressure goes up. if it does and then fires right up, you know the pump is bad. beating on the tank can shock it back to life. but its a temp fix at best.
    where can i get a fuel pump cheap because I dont feel like putting alot into this car other than into motor as is is a doner car but will be my daily for a few months till i pull the motor
  4. #104 Re: Will not start after replcacing fuel rail and injectors
    ebay, you can buy just the pump, take your canister out, swap the pump in your canister, run ya 30 to 50 tops.
    test it first for pressure before tossing money at it.
  5. #105 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Oh absolutely I'm gonna test it b4 lol
  6. #106 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
  7. #107 Re: Will not start after replcacing fuel rail and injectors
    Donating User
    Aug 2016
    MI
    Did you ever varify wheather or not the security light was flashing? It super simple to check and rule out as a possibility. if the pass lock sensor fails you will still get spark, but it will cut power to your injectors. So it will still run on starting fluid. you mentioned replacing the ignition, so that what leads me to believe its related to your issue.
    Also the pass lock wire is the yellow wire that ties into the ignition, if it didnt get hooked up with the new ignition then it wont start.
  8. #108 Re: Will not start after replcacing fuel rail and injectors
    Quote Originally Posted by 05GXPBeast View Post
    Passlock should depend on his year. Anything before 2004 and the fuel system is supposed to prime, the car should fire and then die as long as it's pre 2004.
  9. #109 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    well before the lock cylinder was drilled out and it started with screw driver but there was no wire
  10. #110 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    like I said above but yea mine is an 01 so it just dies after 10 min
  11. #111 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    imma get a pressure tester and get back later
  12. #112 Re: Will not start after replcacing fuel rail and injectors
    Donating User
    Aug 2016
    MI
    Pass lock failure can happen to various GM vehicles from the late 90's to mid 2000's. My grand prix gt is a 2003 and did not fire and die. it would not fire at all unless starting fluid was used. symptoms can vary like crank/ no start or starting then dying. sometimes it just fails for no reason and its so easy to overlook. This just sounds so much like me about a year ago when I was in the same boat.
  13. #113 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    so how did you fix it?
  14. #114 Re: Will not start after replcacing fuel rail and injectors
    you leave the key to run for 10 minutes, then turn it off for less then 10 seconds, then on for 10 minutes again do this 3 times, then the 4 th time it should crank and run.
    so thats key to run 3 times for 10 minutes, turn it off and then it should crank and run on the 4 th key turn. if your battery is weak run a battery charger or you can use jumper cables off a running car to keep your battery alive. you dont want to waste 30 minutes of life 2 times on this.
  15. #115 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    so true lol ill keep a charger on it
  16. #116 Re: Will not start after replcacing fuel rail and injectors
    i forgot to add, you cant open the door or anything once you start this, so either open the window and work the key through the open window, or have snacks and a drink while you sit locked in the car the whole time. use a timer too.
  17. #117 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    oh okay thats why it didnt work when i got it last week thanks!!
  18. #118 Re: Will not start after replcacing fuel rail and injectors
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Lol yeah, it sucks... but better than paying the dealer $100!
  19. #119 Re: Will not start after replcacing fuel rail and injectors
    Jan 2018
    Morgantown
    Quote Originally Posted by wstefan20 View Post
    absolutely
  20. #120 Re: Will not start after replcacing fuel rail and injectors
    Interesting..per the manual, shouldn't work like that. But then again...how many times have we been surprised by "shouldn't" vs actually happened.
  1. fuel rail/injectors
    By buschegt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2013, 02:58 PM
