Thread: Very lean but only sometimes...
Results 1 to 6 of 6
  1. #1 Re: Very lean but only sometimes...
    Kemmerer, Wyoming
    usually there is a vacuum leak when the fuel trims to positive. a misfire will make the fuel trims go lean as well.
  2. #2 Re: Very lean but only sometimes...
    Oct 2011
    Toledo, OH
    Quote Originally Posted by SgtMarshal View Post
    I'd second that. Sounds like vacuum leak unless you are running e85 without a tune.
    7"
  1. I got P0107 low lean.. what should I do?
    By tlawnewtograndprix in forum General Tech Discussion
    Last Post: 04-15-2013, 05:25 PM
  2. lean
    By illy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2012, 07:40 AM
  3. How to lean a car out with DHP
    By dsmuts in forum PCM Tuning
    Last Post: 07-12-2012, 10:18 PM
  4. Lean?
    By Deeter in forum PCM Tuning
    Last Post: 09-17-2008, 05:11 PM
  5. 940 WOT o2 is lean?
    By Bio248 in forum PCM Tuning
    Last Post: 03-04-2008, 05:55 PM
