Thread: Very lean but only sometimes...
Results 1 to 6 of 6
  1. #1 Very lean but only sometimes...
    Jul 2015
    Kalamazoo, Michigan
    Hello, everybody! I just started piecing together some light mods on my 1997 GTP, but every once in a while, the SES light will come on. The code is for a system lean condition, but it clears its self after a few days. I checked the fuel trims at WOT and they are right around 0, but when I'm cruising they go to 16. Is this supposed to happen, or should I get a smoke test done?
  2. #2 Re: Very lean but only sometimes...
    Have you cleaned the MAF lately?
    Negative trims like -16 means it's overally rich, a smoke test won't show you something there. a Postive fuel trim of +16 would mean it's trying to add fuel because it's lean.
    I'd suspect a dirty MAF sensor or leaking fuel injector if the trims are always negative on a factory calibration.
  3. #3 Re: Very lean but only sometimes...
    Jul 2015
    Kalamazoo, Michigan
    whoops, sorry, the trims are in the positive direction, I just went out to double check :P I just replaced the MAF, too.
  4. #4 Re: Very lean but only sometimes...
    Kemmerer, Wyoming
    usually there is a vacuum leak when the fuel trims to positive. a misfire will make the fuel trims go lean as well.
  5. #5 Re: Very lean but only sometimes...
    Oct 2011
    Toledo, OH
    Quote Originally Posted by SgtMarshal View Post
    I'd second that. Sounds like vacuum leak unless you are running e85 without a tune.
    7"
  6. #6 Re: Very lean but only sometimes...
    May 2017
    Dirtyzville, Mizzery
    Check vacuum lines.
    With it being a 97, I'm sure literally everything is dry rotted.
    Replace all of those and do the intake gaskets as well. Could be those, too.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  1. I got P0107 low lean.. what should I do?
    By tlawnewtograndprix in forum General Tech Discussion
    Last Post: 04-15-2013, 05:25 PM
  2. lean
    By illy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2012, 07:40 AM
  3. How to lean a car out with DHP
    By dsmuts in forum PCM Tuning
    Last Post: 07-12-2012, 10:18 PM
  4. Lean?
    By Deeter in forum PCM Tuning
    Last Post: 09-17-2008, 05:11 PM
  5. 940 WOT o2 is lean?
    By Bio248 in forum PCM Tuning
    Last Post: 03-04-2008, 05:55 PM
