Thread: Breather nut?
Results 1 to 20 of 33
  1. #1 Breather nut?
    Nov 2015
    WI
    I went to put a MPS on the car today and found out i dont have a breather nut on the supercharger. Bought the car this way, i know the supercharger was replaced by a dealer before i bought it. guessing i need to get one to install after the MPS is installed.
    Did some searching and found a thread where a guys had his pulley fall off after a year, thats crazy since it press fit.
    What is the main purpose of this breather nut and could there be any damage from not having it one?
    2000 GTP if that makes a difference
  2. #2 Re: Breather nut?
    zzp mps comes with push tree type clip. the bolt will not fit any more cause it cant clear the pulleys bolts.
  3. #3 Re: Breather nut?
    Nov 2015
    WI
    So no need for anything?
  4. #4 Re: Breather nut?
    if you bought a new mps from zzp it comes with the push tree. push it in the shaft end. thats it.
    and if the mps was to ever come off the shaft its not because the bolt was missing. they had bigger issues at hand.
  5. #5 Re: Breather nut?
    Nov 2015
    WI
    i bought a smoothflow system it did not come with anything to put in the end.
  6. #6 Re: Breather nut?
    ahhh, the nut will fit on that brand. i got em myself and use the nut. not the end of the world tho. the push clip can only be there to protect the threads, same as the nut.
  7. #7 Re: Breather nut?
    Nov 2015
    WI
    Is that the only purpose is to protect the threads?
    I will just buy one and be done.
  8. #8 Re: Breather nut?
    i cant see it venting anything. dont even see a breather hole in it.
  9. #9 Re: Breather nut?
    Buffalo
    The center has that porous stone like material in it. I don't think I use it tho
  10. #10 Re: Breather nut?
    Nov 2015
    WI
    Pulled the pulley and the M8x1.25 stud broke off in the supercharger shaft. now i am Fed. i have easy outs i will try but damn why did that happen?
    such a easy project just turned in the a large one.
  11. #11 Re: Breather nut?
    Nov 2012
    Madison
    Quote Originally Posted by GTPNovak View Post
    Yikes, same thing happened to me 10 years ago.
    Hopefully you put the anti-seize on it and it should come out super easy.
    I drilled a pilot hole, dead center with a baby drill and used a small finishing nail( 4d maybe?) tapped in snug. It spun right out
  12. #12 Re: Breather nut?
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Turn it the right way ?
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  13. #13 Re: Breather nut?
    Quote Originally Posted by cheatah faheatah View Post
    if you were to turn it the wrong way it would get loose and fall off lol theres more then one moving part, things need to be held still while you work the drive bolt or the nut on that bolt.
  14. #14 Re: Breather nut?
    you let one part of the puller turn when installing it, only the nut cant turn thus pushing the hub on.
    if it broke off while pulling the pulley, thats cause it was not supposed to be used yet. the threaded rod is for installing only.
  15. #15 Re: Breather nut?
    Buffalo
    ^ yup
    i see a lot of people thread the bolt on then pull the pulley off and of course the bolt snaps
  16. #16 Re: Breather nut?
    May 2016
    Rouge Island
    Idkwtfitaa
  17. #17 Re: Breather nut?
    Nov 2015
    WI
    Well the the instructions said to put it in i had my doubts.
  18. #18 Re: Breather nut?
    off you use the little nub tip that centers the bolt.
  19. #19 Re: Breather nut?
    Buffalo
    You know soo much , I would have taken you for a mod
  20. #20 Re: Breather nut?
    Quote Originally Posted by CrazyGuy03 View Post
    its nice to not give a flying fuk any more. really is.
  1. LIM PCV mod vs breather
    By Keko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2016, 06:42 PM
  2. Installed Intercooler.. Breather or not??
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 10-14-2016, 03:34 PM
  3. Crank case breather
    By xxburkettxx07 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2015, 12:16 PM
  4. Using a breather with an intercooler
    Last Post: 10-04-2014, 06:38 PM
  5. Second valve cover breather
    By Macksauce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2014, 04:11 PM
