Thread: Fuel issue?
Results 1 to 3 of 3
  1. #1 Fuel issue?
    SE Level Member kewGTP's Avatar
    Mar 2015
    Appleton, WI
    I started having this issue about two weeks ago when I went to go get onto the highway, got into boost, car spit and sputtered and died. I threw it in neutral and continued on my trip for the day. Fast forward to the present and I am not sure what I have on my hands, is it the fuel pump? (I am running the stock pump on e85 and 60# injectors) or is it spark related (car has a increasingly hard time to start, even on top of the initial e85 cold starts issues) I am leaning out from 11.2 to 13.2 when the spit/sputtering happens when i attempt to go into any amount of boost so i am kind of thinking it's more fuel related. Someone else has suggested it could be a bad MAF sensor? how would I check that? TIA peeps
    '05 GTP - E85 - XP Cam - 3.0 Pulley - Supporting Mods...
  2. #2 Re: Fuel issue?
    Mar 2015
    Appleton, WI
    I should also mention the car is not throwing any codes. Any help would be appreciated.
  3. #3 Re: Fuel issue?
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    Hook up a fuel pressure gauge. Stick it under the windshield wiper so you can see it. Make a WOT pull and see if your fuel pressure is dropping out. Troubleshoot from there. Might even be able to rent one at AZ or Advance if you don't have one.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  1. Fuel issue
    By Tate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2014, 07:24 AM
  2. Fuel ISSUE!!! E85
    By J2000 in forum General Grand Prix Discussion
    Last Post: 01-22-2014, 01:26 AM
  3. fuel issue?? 99 gtp
    By jman44 in forum Introductions/Noob Questions
    Last Post: 12-20-2013, 06:29 PM
  4. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  5. Another issue, fuel? please help!
    By Pittman06 in forum General Tech Discussion
    Last Post: 01-22-2010, 12:28 AM
