Thread: 1st time tuning/upgrading advice
Page 1 of 7 123 ... LastLast
Results 1 to 20 of 134
  1. #1 1st time tuning/upgrading advice
    SE Level Member Garandpa's Avatar
    Oct 2016
    Davisburg, MI
    I'm making some mods to my 2002 GTP, which is otherwise stock other than MSD Blaster coils (which I have since learned have a so-so reputation). I have a ZZP cat-back exhaust and downpipe inbound, along with the ZZP PCM tune and a 3.5" pulley (per their recommendation), NGK TR6 plugs, wires from 3800 performance, and a 180 degree thermostat, and an alternator voltage booster gizmo. I rented the puller from ZZP and sprung for the modular hub and pulley. I'm going to install aluminum coolant elbows while I've got everything apart as well.
    I'd like to get all of this stuff installed while my wife is out of town in a couple weeks so I'm hoping there aren't a bunch of pitfalls. What am I missing and is there anything in the list above that doesn't sound right or worthwhile? My goal is just to have a bit sportier ride for the summer months here in Michigan. I always run 93 octane gas, which is plentiful here.
    Thanks,
    Roy
  2. #2 Re: 1st time tuning/upgrading advice
    get headers and a 3.4 if your a gen 3 blower.
    headers no matter what.
  3. #3 Re: 1st time tuning/upgrading advice
    Kemmerer, Wyoming
    in Michigan it seems like all the people who live there want to run E85 because of it's anti knock index. if you swap injectors to 42's or 60's you could run something like a 3.3 or 3.2. a downpipe is easier to install, but with headers you get a lot more flow. but headers are also more work to install.
  4. #4 Re: 1st time tuning/upgrading advice
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    ^^^ headers fer sure.
    And a mail order tune is always an eh upgrade, the real upgrade would be a proper tune from either a reputable shop that knows how to tune a 3800, or a local friend with a tuner.
    Mail order tunes, or "canned" tunes never get the full potential that an actual tune will, because every car is different and canned tunes are all the same.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  5. #5 Re: 1st time tuning/upgrading advice
    Mar 2014
    Tucson
    Scanning for knock?
  6. #6 Re: 1st time tuning/upgrading advice
    ZZP and "recommendation", lol.
  7. #7 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Maybe next year for headers. I only have another month (tops) to drive this car, so I've pretty much shot the wad on upgrades for this year.
  8. #8 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Meaning what, exactly?
  9. #9 Re: 1st time tuning/upgrading advice
    then dont do any thing to it. ZZP lies to sell parts, they really do suck. good chance the engine blows on ya as per their recommendation.
  10. #10 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Am I missing part of this conversation?
  11. #11 Re: 1st time tuning/upgrading advice
    you are, zzp lies and sells crappy tunes on top of the lies. but your new and dont know any better yet. i mean why would you question a leading parts seller like zzp?
    they are not the only game in town, most of what they sell can be found cheaper else where, or used. headers dont have to cost 800 bucks either, but zzp thinks they should.
    for headers most of us run speed daddy headers, 220 shipped most of the time. add some band clamps and your all set. for 250 in all.
  12. #12 Re: 1st time tuning/upgrading advice
  13. #13 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    O.K., thanks. Great info. Headers are not happening this year. I know they're the greatest thing since sliced bread, but not in the cards right now. Maybe next year. I doubt I can return my ZZP PCM, but I'm checking into it. If I can't, perhaps I'll have 3800 Performance flash mine.
  14. #14 Re: 1st time tuning/upgrading advice
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    Yeah cancel your ZZP order, ZZP PCM is trash, ZZP catback exhaust adds no performance benefit (unless over like 350hp or something) just mass drone. Get SD headers for like $200, a PCM tune from Overkill and drop to a 3.4......or just listen to ZZP and their lies and chip a piston, your call.
  15. #15 Re: 1st time tuning/upgrading advice
    Kemmerer, Wyoming
    Quote Originally Posted by Lishap View Post
    Yeah cancel your ZZP order, ZZP PCM is trash, exhaust adds no performance benefit just mass drone. Get SD headers for like $200, a PCM tune from Overkill and drop to a 3.4......or just listen to ZZP and their lies and chip a piston, your call.
    you need to clarify that statement because exhaust work is where many gains can be made. I think you meant catback, and even then there are situations where gains can be had, not every situation, but some.
  16. #16 Re: 1st time tuning/upgrading advice
    Jan 2012
    New York
    Corrected.
  17. #17 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    No can return ZZP PCM, so worst case I'm out $125 if I order the 3800 Performance version. Overkill is twice as much $$.
  18. #18 Re: 1st time tuning/upgrading advice
    May 2012
    Where winter never ends
    Doesn't ZZP lock their PCMs?
    2000 Regal - Winter Beater
  19. #19 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    So the 3800 performance PCM recommends a 3.4" pulley. Are 3800 Performance pulleys interchangeable with ZZP's? (I bought ZZP's hub and a 3.5" pulley).
  20. #20 Re: 1st time tuning/upgrading advice
    Kemmerer, Wyoming
    zzp doesn't lock their pcms. if you have an opportunity, I would get a maf adjustment done because it is likely that your fuel trims will run rich with the zzp adjustment. zzp and intense modular pulleys are interchangeable, and for that reason, most people use the zzp hub or intense hub. those are the most common pulleys out there. 3800 performance has been declining in popularity for quite some time.
  1. Tuning advice
    By TEK310 in forum PCM Tuning
    Last Post: 12-29-2013, 10:01 AM
  2. Replacement time looking for advice
    By TeacherCreature in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2013, 06:59 AM
  3. need tuning advice
    By asite57 in forum PCM Tuning
    Last Post: 04-22-2012, 10:39 PM
  4. advice on upgrading a stock '98 gt
    By mhoran89 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 04:56 PM
  5. Tuning Advice?
    By Lawngoose in forum PCM Tuning
    Last Post: 10-15-2008, 09:03 PM
