Thread: 1st time tuning/upgrading advice
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 21 to 40 of 134
  1. #1 Re: 1st time tuning/upgrading advice
    Aug 2016
    MN
    Quote Originally Posted by Garandpa View Post
    No can return ZZP PCM, so worst case I'm out $125 if I order the 3800 Performance version. Overkill is twice as much $$.
    I think overkill will give you a $50 credit if they are using a competitor's core. Just a thought. I will say that I was able to raise my mpgs a fair amount when I tuned it myself. I added a bunch of timing to the cruise tables, way more than any of the canned tunes I've seen have.
    1998 Grand Prix GTP aka The Family Sedan
    CAI, 1.8 rockers, U-bend delete, 3.4 pulley, tuned by me
    1999 Turbo Grand Prix
    L36 turbo build in progress
  2. #2 Re: 1st time tuning/upgrading advice
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    Quote Originally Posted by Mitch R View Post
    Same here! I CAN get almost 30+ IF i can keep from going deep and making her whine... I mean make boost. LOL
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  3. #3 Re: 1st time tuning/upgrading advice
    May 2012
    Where winter never ends
    Doesn't ZZP lock their PCMs?
    2000 Regal - Winter Beater
  4. #4 Re: 1st time tuning/upgrading advice
    Kemmerer, Wyoming
    zzp doesn't lock their pcms. if you have an opportunity, I would get a maf adjustment done because it is likely that your fuel trims will run rich with the zzp adjustment. zzp and intense modular pulleys are interchangeable, and for that reason, most people use the zzp hub or intense hub. those are the most common pulleys out there. 3800 performance has been declining in popularity for quite some time.
  5. #5 Re: 1st time tuning/upgrading advice
    zzp pcm's are not locked. you can read them with dhp or hpt. ive re tuned 3 of them so far.
  6. #6 Re: 1st time tuning/upgrading advice
    May 2012
    Good, they stopped doing that. I have a couple ZZP pcms from way back when and they are tuner locked. Most annoying thing ever.
  7. #7 Re: 1st time tuning/upgrading advice
    SE Level Member Garandpa's Avatar
    Oct 2016
    Davisburg, MI
    So let's say for argument sake I decide to add Speed-Daddy headers to this upgrade. What do I need from there on back for the exhaust system (down pipe/no down pipe; cat-back)? How hard is this install? Do I need to pull the engine, or is this a bolt-on sort of a proposition?
  8. #8 Re: 1st time tuning/upgrading advice
    if you have inspection you would need a 3 inch hi flow cat, headers come with a down pipe but no cat. in the tune the cat and rear o2 deleted.
    its bolt on, remove the old stock factory manifolds and the headers replace it. they bolt right up to your cat back. theres no need to up grade the cat back, theres no gains, unless you like noise.
    the cat you can band clamp in, or weld it in at a shop or diy welding.
  9. #9 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    I have no Cat-back currently: all stock (see original post). My cat-back is back-ordered from ZZP. Speaking of which, should I wait for it or are their exhaust parts full of lies and evil spirits too? Regardless there is no "inspection" in Michigan. You can run what ya got. As far as just remove the exhaust manifold and replace with headers goes, I have no lift, just jack stands in the driveway or single bay garage. Still no big deal?
  10. #10 Re: 1st time tuning/upgrading advice
    jack stands will do. most of use do all our work in the driveways on our backs.
    that exhaust is loud as hell. no idea if you will like it at all. most who get it, sell it. its cool for maybe a month and then your ears hurt. unless your a 17 year old, then maybe you'll like it, but judging by your s/n your not a teen lol
  11. #11 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Ha! Pretty far from a teen. Let's just say I'm at an age where I can afford a bunch of crap I don't actually need for my GTP. I do want some better sound, but I ordered the resonator too. I assume with the resonator and mufflers, it's not too loud.
  12. #12 Re: 1st time tuning/upgrading advice
    oh its loud lol. you'll see.
    im not a kid either, and from what ive heard in person, i dont want anything but a stock cat back. a 3800 will never have that v8 sound or tone. its not bad at a idle, but the rest is a wet fart sound to me, nothing like all the back fires and popping out the pipes when you let off the gas either to make it sound even more like crap.
    i like the sc whine to be heard and thats all.
  13. #13 Re: 1st time tuning/upgrading advice
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    If it was me I would return the catback, alternator booster, and coils. No performance gain. Annoying drone with the catback. Buy a set of Speed Daddys off Ebay. Have them powdercoated. Buy a high flow cat, some band clamps, and follow the install thread on here. Tune out the rear O2 or run it (extend the wires) with the non-fouler trick. I run a ZZP canned tune. I am happy with it. Many aren't. Soon to be dyno tuned. Scan for knock with a OBDLink LX and Torque Pro. Run a cone, CAI, or modded stock airbox with drop-in K&N. If you are done with mods get a dyno tune and enjoy. Definitely read the mod thread. Parts are expensive at ZZP. I buy some stuff on there and shop around for others where cheaper. They run a black Friday special.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  14. #14 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Too late for the coils, I've run those for a year. Probably kept the stock ones though. I'm liking the sound of the header route more and more. And thanks for the post. Very helpful.
  15. #15 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    So I'm ready to drink the header kool aid; can I make my other mods before the headers or do I need to do headers first and then my canned tune? In other words, is it safe to drive my car after the tune if I don't do anything to the exhaust for a week or so?
  16. #16 Re: 1st time tuning/upgrading advice
    Omaha, NE
    I would do headers before you put the 3.5 pulley and tune in the car. The headers will reduce the likelihood of Knock Retard which will prolong the life of your 3800.
  17. #17 Re: 1st time tuning/upgrading advice
    you can run the pcm but dont dare drop the pulley till the headers are on. mod one is always headers or plog down pipe combo. plog and dp cost more, and good lick finding a plog, zzp is out of stock for like a year now iirc.
    unless you want to install rockers and springs, those can be installed with no other mods and still help the engine flow better. stock i had 8º KR, rockers killed off 5º of that kr, stock tune and everything else.
  18. #18 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Ok, so what cat do i need with speed-daddy headers?
  19. #19 Re: 1st time tuning/upgrading advice
  20. #20 Re: 1st time tuning/upgrading advice
    Oct 2016
    Davisburg, MI
    Done. Does this bolt on or weld?
  1. Tuning advice
    By TEK310 in forum PCM Tuning
    Last Post: 12-29-2013, 10:01 AM
  2. Replacement time looking for advice
    By TeacherCreature in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2013, 06:59 AM
  3. need tuning advice
    By asite57 in forum PCM Tuning
    Last Post: 04-22-2012, 10:39 PM
  4. advice on upgrading a stock '98 gt
    By mhoran89 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 04:56 PM
  5. Tuning Advice?
    By Lawngoose in forum PCM Tuning
    Last Post: 10-15-2008, 09:03 PM
