Thread: Help! High Boost?
Results 1 to 20 of 33
  1. #1 Re: Help! High Boost?
    with those miles, and it sat for 4 years, tune up is "the" first thing id do, and a oil change. why did you change all that other stuff? that was the cost of a tune up i bet.
  2. #2 Re: Help! High Boost?
    SE Level Member HardTail's Avatar
    Sep 2016
    Georgia
    She wasn't running when I bought her. So I took a electric in line fuel pump bypassed all the other and she fired up. Old pump and tank was crap and I mean crap. so I started from there and worked towards the engine. Don't get me wrong If it is the converter then I will buy the rest for the tune up. I just want to make sure the motor and supercharger is working fine. If not then it will become a parts car and I will look for another GTP. Does that make sense? And yes I changed the oil already. Tranny will be next with the tune up if the cat is truly the case.
  1. Boost strangely high for my mods?
    By kyle91 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2011, 11:46 AM
  2. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  3. LS swap or high boost
    By Lambda in forum General Tech Discussion
    Last Post: 08-13-2011, 05:07 PM
  4. High Boost
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 06:03 PM
  5. 3.4 Installed, still have KR and high boost-now what?
    By Liquifire in forum General Tech Discussion
    Last Post: 10-25-2009, 08:51 AM
