Thread: 3.4 Installed, still have KR and high boost-now what?
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 3.4 Installed, still have KR and high boost-now what?
    Wausau, WI
    I think I know the answer to this already but would appreciate any advice that I can get with this issue(s). I just got done installing my 3.4 MPS, 3800 PCM, AL104's. Now, I should have enough supporting mods to safely run the 3.4 set-up. I am getting as much as 12lbs of boost, and as high as 4* of knock at the top of second gear. What is my best bet to get rid of the knock? It runs awesome and feels good, but I am concerned with the knock. I am NOT going to put on headers, so please don't suggest that. Is it just all in the tune? I wanted to buy a 3.5 but they are all sold out right now and not available. I don't mind spending the time and money to get rid of the KR, but I will not be going beyond the 3.4 set up. I may go with roller rockers but I dont know how this will affect gas mileage and knock. I realize porting my LIM and SC would reduce my boost, but would it help with KR or not really? I never had any knock at all with my 3.8 but I did have boost on the top end of 7-9psi. With the 3.4 and the raised shift points I am now @ 12lbs.It is only 35 degrees here and I hate to see what it will be in the summer. When is the best time to tune a car? Is it when the worst case scenario presents itself? Warm weather or cold, does it matter?If there are any more questions that I can answer please let me know. My upgrades should be in my sig. Any real advice is welcome. Thanks again people....
  2. #2 Re: 3.4 Installed, still have KR and high boost-now what?
    the best way to get rid of that knock is to get a better tune. youre almost certainly going past your threshold limits and that KR is kind of false, but true at the same time. if you do not have any access to a tune then youre going to have to jump on the rocker train for a little more flow in your motor. ported blower/LIM/TB might help, but not as much as you would want it to. if you have 4* now, when its 0* outside youll have much more. when its hot you wont see as much knock because you wont be running as much timing.
    if you dont want to do any of this then get a happy knob or a tune and run low timing.
  3. #3 Re: 3.4 Installed, still have KR and high boost-now what?
    Wausau, WI
    what type of gains power wise would I see with 1.8 RR's...I should be able to run these with stock springs and retainers, right? I will find someone who tunes if that is what it takes, I will have to go to Iowa or Illinois I guess....
  4. #4 Re: 3.4 Installed, still have KR and high boost-now what?
    with rockers you MIGHT gain another 10-15 whp maybe and you could run them with stock springs.
    your best bet is a tune. you car should run great after you get a good one, but until then i would suggest pulleying up so you dont knock a lot in the winter. i was seeing upwards of 14-15 psi on my 3.4 last winter which is way too much.
  5. #5 Re: 3.4 Installed, still have KR and high boost-now what?
    Wausau, WI
    I just wont get on it until I can get a different pulley. I got a stock size to fit the MPS and the 3.4 but they didn't have a 3.5 available now. You think a 3.5 or 3.6 is my best bet until I can get it tuned?
  6. #6 Re: 3.4 Installed, still have KR and high boost-now what?
    it wouldnt hurt, but you could always just be nice to it until then. 4* on a 3.4 isnt that much knock, but over enough time it could cause problems if youre constantly in the throttle.
  7. #7 Re: 3.4 Installed, still have KR and high boost-now what?
    GT Level Member BoostedComp's Avatar
    Youngstown
    Quote Originally Posted by Liquifire View Post
    i would go with the 3.6 until your tuned... if your gonna have the 3.4 pully on hand, you miaswell bump up to a 3.6 for a winter pulley just to have. if its any reasurance, i have pretty much the same flow mods as you with a 3.6 and i dont have any knock, and i also have the gen 5 blower
  8. #8 Re: 3.4 Installed, still have KR and high boost-now what?
    Banned - Busted For Scamming
    Feb 2009
    I see 7psi MAX on my 3.4 setup. This is because it flows really good. Headers, rockers, ported m90. You really just need some flow mods.
  9. #9 Re: 3.4 Installed, still have KR and high boost-now what?
    Jan 1970
    Maquoketa, Iowa
    Could unplug the BBV and see if you are getting the same knock first, it will limit the boost to 3-5psi.
    Also, 4* isn't that bad either, how long have you been driving the car since you dropped to the 3.4 and put the pcm in? The fuel trims could be still learning themselves and you can be locking the LTFT's in rich/lean causing the car to lean out or dump fuel when in PE or throughout your upper rpm's.
  10. #10 Re: 3.4 Installed, still have KR and high boost-now what?
    Portland Oregon
    Psh, I'm bone stock with a 3.8 pulley and I see flash kr up to 5*. Stupid stock tune and torque management.
  11. #11 Re: 3.4 Installed, still have KR and high boost-now what?
    Wausau, WI
    Quote Originally Posted by FoSHO99 View Post
    about 20 hrs since they were put on. about two hours drive time. So how do I drive it for now(I am assuming stay out of knock as much as possible) so that it does learn the proper trims and how long should it take to re-learn the trim's? I guess the 3800 pcm is not tuned to much to get rid of knock, or it is so individualized that I just need a custom tune, or everyone does...
  12. #12 Re: 3.4 Installed, still have KR and high boost-now what?
    Youngstown
    Quote Originally Posted by OH4CompG View Post
    mine was about the same... got an overkill pcm... knock be gone. its incredible how poorly tuned these cars are from the factory
  13. #13 Re: 3.4 Installed, still have KR and high boost-now what?
    Charles City, IA
    I will sell you a 3.5 for $35 shipped.
    SMGPFC Two Nipple General
  14. #14 Re: 3.4 Installed, still have KR and high boost-now what?
    not to kill your sale, but a 3.5 probably wont make enough of a difference to matter. its just cold outside and hes running more timing/boost than normal. in the spring/summer i bet the car doesnt knock if it had a good tune.
  15. #15 Re: 3.4 Installed, still have KR and high boost-now what?
    Charles City, IA
    Yeah, I just want to get rid of it so I have some cash to buy a 3.2
  16. #16 Re: 3.4 Installed, still have KR and high boost-now what?
    Wausau, WI
    It probably doesnt help that I am running 200 more RPM's either at the top end. In first I only get just over 1* of knock and towards the top of second gear it starts getting bad. I will just take it easy most of the time until I get a custom tune.(Fosho or FastKatt maybe) Don't know for sure as I have talked to neither of them, but it seems the best logical thing to do. So is it best to tune it in the winter, summer, spring, fall or does it not matter at all?
  17. #17 Re: 3.4 Installed, still have KR and high boost-now what?
    Charles City, IA
    You need to tune for the differnt weathers.
  18. #18 Re: 3.4 Installed, still have KR and high boost-now what?
    if you do a conservative enough tune you shouldnt have to worry about weather, just pulley up a little bit in the winter.
  19. #19 Re: 3.4 Installed, still have KR and high boost-now what?
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    Yeah that sounds about right. I mean colder air is more dense so u would see more kr in the winter. From what I've heard 4* aint bad. I'm not even sure what I have for kr
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
  20. #20 Re: 3.4 Installed, still have KR and high boost-now what?
    Wausau, WI
    so how big of a difference are we talking in PSI? If I run a 3.4 in the summer at 80-90* should I be back to a stocker when it is 0* or would a 3.6 be a good bet?
  1. FWI installed!! ...still not getting full boost though...
    By 03GTPLE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2009, 04:20 PM
  2. Installed PLOG, now studders under boost. Please help!
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 10:07 AM
  3. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
  4. High Flo Cat
    By 04gpking85 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:24 AM
