Thread: Help! High Boost?
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: Help! High Boost?
    SE Level Member HardTail's Avatar
    Sep 2016
    Georgia
    Got ya. just asking. Only reason looking at replacing cause its been sitting. I know my GT water pump went out a around 100k so was thinking about that.
  2. #22 Re: Help! High Boost?
    when it fails worry about it. id focus on making it run well.
  3. #23 Re: Help! High Boost?
    Kemmerer, Wyoming
    the problem with the electric wp is cost. you might free up 10 hp for 350 dollars. the electric wp's don't have near the longevity of an oem unit.
  4. #24 Re: Help! High Boost?
    hangover park IL
    ~4-5 really.
    ~James~ Psychotic Gearhead
  5. #25 Re: Help! High Boost?
    Quincy, Mass
    Have you checked to make sure the vacuum lines on the bbs aren't dried out and cracked?
    No more GP 04 Impala SS Indy:
  6. #26 Re: Help! High Boost?
    Sep 2016
    Georgia
    And the winner is the Cat. Took it completely off and gave her a test drive.
  7. #27 Re: Help! High Boost?
    Sep 2016
    Georgia
    If I had a vacuum leak wouldnnt that cause low boost
  8. #28 Re: Help! High Boost?
    whats low? and how you reading it? all you got is lego blocks on the dash there. they kinda blow. stock is like 7 to 8 psi, with no cat or u bend maybe 6 to 7 psi.
  9. #29 Re: Help! High Boost?
    Sep 2016
    Georgia
    I was replying to the post they were telling me about a vacuum leak. Now next issue is to put a Magna Flow cat on it or decat it. Suggestions?
  10. #30 Re: Help! High Boost?
    a good cat that wont set the cel for no cat, as a hi flow cat can do that. unless you plan on modding it and getting it tuned. and deleting the cat and rear o2 sensor.
  11. #31 Re: Help! High Boost?
    Sep 2016
    Georgia
    I plan on Mod'ing it. That's what I bought it for. Gave 800 bucks for it now I got 1k in it. I pulled out the welder and brushed up on my welding skills and deleted the cat. But made it where I can run O2 sensors in it. Tried to upload pics of what I did but keeps saying upload failed. Also got rid of the u bend in the pipe. Will try to upload pics agian.
  12. #32 Re: Help! High Boost?
    you need to host your pics on line some where, fb, photobucket what have you, then link it here. upload pc to the site does not work well.
  13. #33 Re: Help! High Boost?
    Omaha, NE
    Quote Originally Posted by hardtail View Post
    side note i will probably replace the water pump if the cat is the issue. Electric or stock?
    hWhat?
  1. Boost strangely high for my mods?
    By kyle91 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2011, 11:46 AM
  2. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  3. LS swap or high boost
    By Lambda in forum General Tech Discussion
    Last Post: 08-13-2011, 05:07 PM
  4. High Boost
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 06:03 PM
  5. 3.4 Installed, still have KR and high boost-now what?
    By Liquifire in forum General Tech Discussion
    Last Post: 10-25-2009, 08:51 AM
