Thread: Car Sputters
Results 41 to 60 of 79
  1. #41 Re: Car Sputters
    He's 04+, they have less vacuum lines.
    If no vacuum leak is found, then revert to the P0068/101 code. Either the circut to the maf is the issue, the maf itself or the MAP sensor is the problem. Not saying you have to shotgun parts at it, but you need to diag them one at a time to see where the problem lies.
  2. #42 Re: Car Sputters
    May 2012
    Canada , Sarnia
    so today before I drove the girlfriend to work I sprayed the lines down fast and wiggle the wires now it seems to be running good not bogging through the rpms
  3. #43 Re: Car Sputters
    May 2012
    Canada , Sarnia
    ok so the problem came back today when my mom was using my car went to where she parked it cleared the code started right up but sputtering climbing through the rpms again
  4. #44 Re: Car Sputters
    May 2012
    Canada , Sarnia
    tonight I was going it again and found a rip in the boot that runs from my CAI elbow to the throttlebody could this be why my car is running bad and the P0507 code ??
    Car Sputters Attached Images
  5. #45 Re: Car Sputters
    if thats between the maf sensor and TB, and was real loose, yeah it could.
  6. #46 Re: Car Sputters
    May 2012
    Canada , Sarnia
    could I use something to fix it for now to get around till tomorrow ??
  7. #47 Re: Car Sputters
    you could try some tape, but that never seems to last long.
    if you go to the parts store im sure you can find something in the help section to fix that up.
  8. #48 Re: Car Sputters
    May 2012
    Canada , Sarnia
    just tried to tape didn't help much lol dosent sputter so much tho when climbing through the rpms
  9. #49 Re: Car Sputters
    wrap a few layers of tape around the nipple, put the vac boot/elbow back on, it should fit snug now, then tape the vac elbow. that would be the best your gonna get for a temp fix there.
  10. #50 Re: Car Sputters
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    zip tie
  11. #51 Re: Car Sputters
    May 2012
    Canada , Sarnia
    and what is that part I need to get a new elbow ?
  12. #52 Re: Car Sputters
    May 2012
    Canada , Sarnia
    they didn't have a elbow so the gave me a piece of tube to use for now had to go to the gm dealer to order the elbow but the car is still giving me the P0507
  13. #53 Re: Car Sputters
    you clear the code? or you just waiting to see if it goes off on its own? cause that can take a while to happen.
  14. #54 Re: Car Sputters
    May 2012
    Canada , Sarnia
    nope cleared it and came back on
  15. #55 Re: Car Sputters
    May 2012
    Canada , Sarnia
    and I also ordered the Ac Delco PVC Kit - 89017274 because one side of the clips that hold the map sensor broke a while ago
  16. #56 Re: Car Sputters
    May 2012
    Canada , Sarnia
    so now im getting the P0449 now everytime I start my car
  17. #57 Re: Car Sputters
    http://engine-codes.com/p0449_pontiac.html evap leak pretty much. gas cap on tight? first thing to check.
  18. #58 Re: Car Sputters
    May 2012
    Canada , Sarnia
    yup checked that
  19. #59 Re: Car Sputters
    it could be the purge solenoid, or the other one on top of the canister in the rear quarter panel. or bad wires to one of the sensor, or its unplugged maybe.
  20. #60 Re: Car Sputters
    May 2012
    Canada , Sarnia
    I did the one in the rear last month and I just put a new one on the one behind the throttle body
  1. Car sputters when stepping on the gas
    By Zinister09 in forum General Grand Prix Discussion
    Last Post: 07-07-2014, 10:14 AM
  2. Sputters under WOT
    By Garet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2014, 10:05 AM
  3. Car sputters when trying to boost
    By Beelzeboul in forum General Tech Discussion
    Last Post: 08-26-2012, 06:31 PM
  4. 97 gtp. Sputters on startup
    By djs4021 in forum General Tech Discussion
    Last Post: 10-26-2011, 12:55 PM
  5. car sputters really bad
    By undecided in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 11:31 PM
