Thread: Car Sputters
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 79
  1. #1 Car Sputters
    May 2012
    Canada , Sarnia
    When I car gets in the 80-100 km range when I let off the gas the car sputters could there be an leak the exhaust ?
  2. #2 Re: Car Sputters
    being its cold out. on a cold start look under the car, any leaks you have will have cold exhaust leaking form the pipe or res, or mufflers.
    or the down pipe to rear manifold.
    you can also block the tail pipes up some to make it show, twist a rag in the tail pipes of one muffler that will give it more pressure with out the car stalling out.
  3. #3 Re: Car Sputters
    May 2012
    Canada , Sarnia
    Will try tomorrow morning must be near the back just replaced the flanges where the cat and resonator meet
  4. #4 Re: Car Sputters
    May 2012
    Canada , Sarnia
    looked yesterday morning the exhaust is fine
  5. #5 Re: Car Sputters
    May 2012
    Canada , Sarnia
    another question every morning when I start my car is runs really rough for a couple of minutes then runs fine like revs ups every couple seconds
  6. #6 Re: Car Sputters
    Sep 2014
    Worcester, MA
    Does the car have a fresh set of plugs & wires?
    Are any of the fluids low (i.e. antifreeze)?
    What year is your car?
  7. #7 Re: Car Sputters
    May 2012
    Canada , Sarnia
    its a 2004 and I was going to do a tuneup soon and all the fluids are good
  8. #8 Re: Car Sputters
    May 2012
    Canada , Sarnia
    this morning took apart my cold air intake to get to the MAF cleaned that and sprayed some throttlebody cleaner in the throttlebody will see how it runs tomorrow morning but got a P0068 code now
  9. #9 Re: Car Sputters
    May 2012
    Canada , Sarnia
    tonight on the way home car was running like crap kept sputtering
  10. #10 Re: Car Sputters
    Sep 2014
    Worcester, MA
    is your air filter clean?
  11. #11 Re: Car Sputters
    May 2012
    Canada , Sarnia
    haven't cleaned the filter since I installed the CAI probably due
  12. #12 Re: Car Sputters
    thats not doing it if its a open cone.
    there was a guy who air box that had a few plastic bags sucked into it, starving it for air.
  13. #13 Re: Car Sputters
    May 2012
    Canada , Sarnia
    wanted to do the seafoam today but got nailed with snow going to wait till the roads are better
  14. #14 Re: Car Sputters
    May 2012
    Canada , Sarnia
    got the seafoam wheres the vac line on the 04's
  15. #15 Re: Car Sputters
    pull the hose off the brake booster. pour the sea foam in that line. go watch a you tube vid, they show how to do it.
  16. #16 Re: Car Sputters
    May 2012
    Canada , Sarnia
    found the hose and poured the seafoam in and waited 20 mins and ran it but the car still sputters when climbing up the rpms what could it be ?
  17. #17 Re: Car Sputters
    Compression check and pull valve covers to see if a valve spring is broken.
  18. #18 Re: Car Sputters
    May 2012
    Canada , Sarnia
    do you guys think I should just do a tune up
    - new plugs , wires , ignition coils , pvc valve , fuel filter , and I was going to get Ac Delco brand car is getting frustrating
  19. #19 Re: Car Sputters
    May 2012
    Canada , Sarnia
    So my car just started acting up in Tim Horton's drive through it was acting like when I unplug the mad sensor and got a P0507 code cleared it and car run normal now could my mad sensor be shot ?
  20. #20 Re: Car Sputters
    car at idle, tap the maf. see if it acts up any. if it does that maf is bad maybe.
    what brand did you use? aftermarket? or a acdelco maf?
  1. Car sputters when stepping on the gas
    By Zinister09 in forum General Grand Prix Discussion
    Last Post: 07-07-2014, 10:14 AM
  2. Sputters under WOT
    By Garet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2014, 10:05 AM
  3. Car sputters when trying to boost
    By Beelzeboul in forum General Tech Discussion
    Last Post: 08-26-2012, 06:31 PM
  4. 97 gtp. Sputters on startup
    By djs4021 in forum General Tech Discussion
    Last Post: 10-26-2011, 12:55 PM
  5. car sputters really bad
    By undecided in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 11:31 PM
