Thread: open end wrench that can take off downstream o2 sensor?
Results 1 to 18 of 18
  1. #1 open end wrench that can take off downstream o2 sensor?
    Jul 2014
    Phoenix, AZ
    I dont want to buy a specialized socket if i have a wrench thay can do it
    Thx
  2. #2 open end wrench that can take off o2 sensor?
    Jul 2014
    Phoenix, AZ
    Thx
  3. #3 Re: open end wrench that can take off o2 sensor?
    St. Louis
    Sure, you can get it with a wrench. IIRC it's a 7/8's. Might do better if you have a short wrench. I replaced the one on my 00GT with just a wrench. Best chance of getting it out is to soak it w/ PB Blaster for a day or 2 then try and remove it while the manifold is still slightly warm (assuming you are talking about the upstream 02 sensor).
  4. #4 Re: open end wrench that can take off o2 sensor?
    Jul 2014
    Phoenix, AZ
    Yea im talkim bout the downstream. im going to put o2 sensor extensions because of the hi flo cat
  5. #5 Re: open end wrench that can take off o2 sensor?
    Enfield, CT
    Quote Originally Posted by MrDniceL36 View Post
    Always used a 7/8ths wrench to take off the downstream o2 off. As for the upstream, if you ever need to do it, rent the special socket from AAP
  6. #6 Re: open end wrench that can take off o2 sensor?
    Jul 2014
    Phoenix, AZ
    Thx everyone!
  7. #7 Re: open end wrench that can take off o2 sensor?
    Mar 2014
    Tucson
    Probably won't need to soak it because... Arizona. LOL!
  8. #8 Re: open end wrench that can take off o2 sensor?
    Dec 2012
    Where 4T65E's were born
    In my experience, having the correct closed end wrench is the best way to remove them. Of course you remove them when replacing, so I cut the end off to slip the closed end over it.
    Sold.
  9. #9 Re: open end wrench that can take off downstream o2 sensor?
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Harbor freight has an o2 socket for less than 10 bucks, tho you can usually get it off without a special one.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  10. #10 Re: open end wrench that can take off downstream o2 sensor?
    Arizona
    7/8ths
  11. #11 Re: open end wrench that can take off downstream o2 sensor?
    Mar 2014
    Tucson
    I used a standard combination wrench when I put mine back in during my header install. Some O2 sensor bungs have a protector ring welded in place around them. Ours don't. That's the only reason I can see needing the special socket. Only if you can not physically get a wrench around it.
    If I'm wrong I'm sure someone with more experience will chime in. Just going on my experience.
  12. #12 Re: open end wrench that can take off downstream o2 sensor?
    Jul 2014
    Phoenix, AZ
    I'm putting 2 o2 extenders on for my hi flo zzp stainless 3 inch catted dp. I got a code sayin the downstream was burnt right after i put on my hi flo magnflow dp. Hope the o2 still works after putting the o2 extensions on!
  13. #13 Re: open end wrench that can take off downstream o2 sensor?
    Antioch, IL
    7/8th, hit the end of wrench with a hammer to tighten it, then hit with hammer to loosen it, piece of cake.
    2009 Challenger SRT8
    Expert at being gay.
  14. #14 Re: open end wrench that can take off downstream o2 sensor?
    Arizona
    Holy **** another az member
  15. #15 Re: open end wrench that can take off downstream o2 sensor?
    Jul 2014
    Phoenix, AZ
    Lool yep native
    Btw i was wondering if I could use a bic lighter to clean my o2 sensor? I dont jave a propane torch
  16. #16 Re: open end wrench that can take off downstream o2 sensor?
    why do you need extensions for the rear o2? and why 2 of them?
    and whats the code you got?
    buy a new o2 sensor.
  17. #17 Re: open end wrench that can take off downstream o2 sensor?
    Jul 2014
    Phoenix, AZ
    Po141. But ive cleared it. Driven 20 miles then the light goes on
  18. #18 Re: open end wrench that can take off downstream o2 sensor?
    thats your up stream sensor, the one in the rear exhaust manifold. not the post cat one.
    http://www.obd-codes.com/p0141
  1. no downstream 02 sensor on my 04 Impala SS at the moment, is that ok ?
    By ryangtp89 in forum General Grand Prix Discussion
    Last Post: 07-11-2014, 07:24 PM
  2. What you guys using for an oxygen sensor wrench?
    By J7319M in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2013, 11:10 AM
  3. o2 sensor ( downstream) STUCK!!!!!
    By mtnman in forum General Tech Discussion
    Last Post: 03-20-2013, 10:32 PM
  4. Can't get downstream 02 sensor off
    By chantspel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-22-2010, 12:25 PM
  5. downstream oxygen sensor replacement help!
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2010, 08:41 PM
