Thread: downstream oxygen sensor replacement help!
Results 1 to 8 of 8
  1. #1 downstream oxygen sensor replacement help!
    utah
    So im at my wits end! I Got the 3 piece tool kit from Autozone and used the 7/8 which worked perfect for the upstream sensor. Basically the lower one is fused with the exhaust system and even after 4 soakings of pb blaster and wd-40 it wont budge...any suggestions???
  2. #2 Re: downstream oxygen sensor replacement help!
    Donating Users kfish's Avatar
    Ohio
    big ol breaker bar
  3. #3 Re: downstream oxygen sensor replacement help!
    in a house
    Quote Originally Posted by kfish View Post
    big ol breaker bar
    ^ that and heat
  4. #4 Re: downstream oxygen sensor replacement help!
    utah
    Is it all that necessary to replace the downstream one? I did the upstream one because I had poor gas mileage, and figured I would just do both...but seriously i cant get this thing off and wondered if its worth the hassle?
  5. #5 Re: downstream oxygen sensor replacement help!
    no...
    all it does is monitor the health of your cat.
  6. #6 Re: downstream oxygen sensor replacement help!
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Kroil...and heat. Also, try working it a touch tighter before rocking to looser.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  7. #7 Re: downstream oxygen sensor replacement help!
    Ohio
    put a pipe on the handle of the breaker bar to extend it some more if need be. itll come out.
  8. #8 Re: downstream oxygen sensor replacement help!
    Portland Oregon
    Once it pops and breaks loose the corrosion it'll come out. Just be careful and work it back and forth with pb blaster.
  1. Crankshaft Position Sensor Replacement [*]
    By SyntheticShield in forum How To Write-Ups/Tech Tips
    Last Post: 11-23-2014, 12:54 AM
  2. Oxygen Sensor
    By BwolfGT in forum Off Topic Discussion
    Last Post: 11-21-2009, 05:44 PM
  3. After cat oxygen sensor installation.
    By English John in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2009, 04:48 AM
  4. oxygen sensor
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 06:20 PM
  5. Falling mileage w/ new oxygen sensor.
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-23-2008, 07:48 AM
