Thread: no downstream 02 sensor on my 04 Impala SS at the moment, is that ok ?
Results 1 to 3 of 3
  1. #1 no downstream 02 sensor on my 04 Impala SS at the moment, is that ok ?
    GXP Level Member ryangtp89's Avatar
    Maine
    just installed my 3" catted downpipe and i couldnt get the old o2 sensor off the stock downpipe soo right now im not running a o2 sensor its an open hole and it sounds like a cut out lol. Is it a bad idea to drive like this for a day or two intil i buy a new downstream 02 sensor ?
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: no downstream 02 sensor on my 04 Impala SS at the moment, is that ok ?
    gardner,mass
    You need a torch to heat up the pipe to get it off the old pipe. Get it almost cherry red and the old o2 sensor will come right out.
    What will happen is your going to throw codes and your car might go into open loop and dump fuel like crazy. Meaning your going to get horrible gas mileage.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #3 Re: no downstream 02 sensor on my 04 Impala SS at the moment, is that ok ?
    Maine
    Old one is stripped. No check engine light a yet. Gotta say she goes soo much better now with the new downpipe
  1. o2 sensor ( downstream) STUCK!!!!!
    By mtnman in forum General Tech Discussion
    Last Post: 03-20-2013, 10:32 PM
  2. Can't get downstream 02 sensor off
    By chantspel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-22-2010, 12:25 PM
  3. Another FML moment
    By quinnp12 in forum The Rant Forum
    Last Post: 02-17-2010, 07:43 PM
  4. downstream oxygen sensor replacement help!
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2010, 08:41 PM
