Originally Posted by 01gpgt01 doesnt take much to make the car run like ass What?? To much fuel pressure??
Originally Posted by amc401 What?? To much fuel pressure?? no a vac leak. FPR's usually fail by droping all pressure. Idle should be around 40 and it should hit 55ish cracking the throttle.
Originally Posted by 01gpgt01 no a vac leak. FPR's usually fail by droping all pressure. Idle should be around 40 and it should hit 55ish cracking the throttle. OK. Do you know where all vac lines are. I only see 3. Two out of same fitting in throttle body and then the brake booster.
Forum Rules
