Ok. So it all started with the transmission not wanting to shift out of 2nd and couldnt get above 3500rpm. Ended up getting a code for O2 sensor. Went to change it and before I could get it in the garage It wouldnt start with out going to full throttle. Once at full throttle and started it ran real rough and would not get above 1200 rpm floored. Pushed it into garage and rescaned computer. Had a multiple miss fire on all cylinders. Went ahead and replaced O2 sensor the next day. Car started up. Ran for a min or two and I shut it off. Finished cleaning up and went to restart and same problem as before. Would not start except under full throttle and had to keep it floored to run. Still not above 1200 rpm. Ok. Time to start looking.
Mass air flow sensor was good.Tested with new one
TPS was good. tested with multi meter and new one
IAC good. Tested with new one. Made sure it was adjusted correctly
Fuel pressure 48 ignition and 55 full throttle running 1200 rpm
Tested with starter fluid and no change. So not fuel pump
Compression test good.
Spark good.
Pulled and cleaned throttle body. No change
Pulled and cleaned PVC. PVC good and no change.
New plugs and wires. No change. ( Was time any ways!!)
Sprayed throttle body cleaner around intake and vacuum lines when it ran and would idle. No change in RPM so i dont think there is a vacuum leak.
Oil or radiator fluid not contaminated by the other.
No codes on computer now.
And starting at full throttle will get it to start still but then dies with in seconds. Cant keep running any more.
Im stumped.
The car is a 01 GT with NA 3.8 and 111k miles.
Any thoughts please?!?!?!?!?!?!?!?!?
