Thread: 3.8 NA fuel line question
Results 1 to 5 of 5
  1. #1 3.8 NA fuel line question
    Nov 2011
    DFW
    I have a 2000 Grand Prix GT with the 3.8 naturally aspirated engine. I have a fuel leak at the connector on the back side of the engine. I tried changing O-rings and it went from a very slight leak to a gusher. Now the question, is that the feed line or the return? My service manual (when I finally located the pics) says it is the feed line. Looks like the return is connected to the fuel pressure regulator. Of course the parts guy ordered the return, but just wanted to clarify. Thanks. BTW, looks like it will be a regal pain to replace..
  2. #2 Re: 3.8 NA fuel line question
    The two line sizes are 3/8 and 5/16. The 3/8 or larger line is the supply.
    What did you order? Dorman makes a partial line fix for this.
  3. #3 Re: 3.8 NA fuel line question
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Quote Originally Posted by hawkeyez View Post
    If you buy the repair kit (sold at most car parts stores) lemme know. I can give you some tips on making the fix ALOT easier. Learned from my own trials
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  4. #4 Re: 3.8 NA fuel line question
    Nov 2011
    DFW
    I ordered the return line. Called the dealer back and got it switched to the supply which they had. Just have to wait for shipping. Not aware of any repair kits. I bought the two bags of O-rings and that made it worse. Undrivable right now.
  5. #5 Re: 3.8 NA fuel line question
    Nov 2011
    DFW
    I did find the repair kit and installed it in about 20 minutes. I was a little worried I would not get the metal union fully seated, but did get it done. No leaks, good to go! Thanks for the repair kit suggestion, OReillys had them hidden..had to ask. Thanks all!
  1. fuel line question
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2012, 03:28 PM
  2. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  3. will a 97-03 L67 SC fuel line fit on my 97 GT L36?
    By mandingo in forum General Tech Discussion
    Last Post: 08-07-2010, 02:53 AM
  4. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  5. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
