Quote Originally Posted by Beelzeboul View Post
usually rough idle means you have a vac leak when you have them scan it for the codes ask if they could look at Your LTFTs (Long term Fuel Trims) if its pegged at 16.4 you got a vac leak to find
No rough idle (as a general rule that is) . It will hesitate and stall if I give it too much gas, it then run fine for a bit then anywhere from 1 to 30 min later do it again. Does it at idle or under load. Regardless thanks for the suggestions. I will get the codes pulled this week and post them up thanks
Sent from my XT910 using Tapatalk 2
